model bluebook BB02
plzzzzzz help to identify this tablet
hi my friend gifted me this tablet . its running on android 2.3.1 , i want to update it to ics or jellybean ...plzzzzzz help me to identify this tablet .plzzz give me links of suitable custom roms ... i rooted it with the help of onerootclick spftware ...plzzzz help me ..here is some information about this...
model bluebook BB02Tags: None
O.k
Here we go, it is a RK29xx based Tablet.
This mean“s may it is possible to get Android 4.1 to this thing, but there a Problems.
Will the Touchscreen work, the Digitizer ?
The is also the Arnova 10G2 there is no Android 4.1 for a long Time because the where no Kernel Sources.
It is possible for you to Open the Tablet and take Pictures from Inside ?
Also can you please Install "Terminal Emulator" and run the follow Commands ?
dmesg >/sdcard
logcat >/sdcard
and post it here or send it to [email protected] ?
Neomode
here it is
k
can i update it to ics version plzzzzzz help me , i only rooted it but i think its not rooted. . plzzz send me suitable cmw recovery and ics rom so i can update it plzzzz help me i dont know what i do ..plzz help me how i root this tablet..here is some other info also
product name - BB02
CPU Chipsets - Cortex A8 core (1.0GHZ)
SDRMA - 512MB DDR3
Flash Memory - 4GB
Touch Panel - Capacitive touch
Display - 7inch Led
Camera - front , CMOS , 2.0 Megapixel
Gravity induction - 3 axis
adobe flash player 10.3 is working
Connection - Usb Type A2.0 high speed port ,
Micro USB 2.0 port
Battery Li-Polymer 3.7v . 3000mAhLast edited by sandhu; 26 July 2013, 12:43.
There are currently 1141 users online. 0 members and 1141 guests.
