Km8 p Amilogic 912.
    Km8 p Amilogic 912.
    KM8P 912 2/16 GIG DEVICE STATED AS ANDROID 7 PROVEN NOT 7 BUT 6.
    Ok time to update a bit since ive had bit of time to test something and play with it for a few hour.
    Ui- Snappy and responsive works well
    Netflicks - Sd working
    You Tube- working
    Video = working
    update progarm- working
    Task Bar - Yes ( Has to be turned on in settings.)
    Sd Card - Working
    Root - Yes
    wifi - Its not the greatest or worst Ive seen but ill adjust the placement and see if simple move helps (with bullet type normally better but works fine.
    network - fine
    bluetooth - No Bluetooth this model.
    Os - Android 6 ---Not Android 7 they may update to it but not as advertized on geekbuying site.
    All in for 54 dollar device not to shabby with good parts seems to but together well. fast stable out of the box.
    Yes and a free piece of lint from factory on cpu heat sink.... Having it checked to see if dna matches a particular cat Ive seen sleeping in Tv Boxes
    http://www.geekbuying.com/item/KM8-P...OX-376335.html
    Ok tear down time lol...
    Click image for larger version  Name:	 Views:	1 Size:	173.6 KB ID:	640154Click image for larger version  Name:	 Views:	1 Size:	226.2 KB ID:	640144Click image for larger version  Name:	 Views:	1 Size:	171.6 KB ID:	640145Click image for larger version  Name:	 Views:	1 Size:	201.9 KB ID:	640146Click image for larger version  Name:	 Views:	1 Size:	243.7 KB ID:	640148Click image for larger version  Name:	 Views:	1 Size:	187.2 KB ID:	640149Click image for larger version  Name:	 Views:	1 Size:	242.1 KB ID:	640152Click image for larger version  Name:	 Views:	1 Size:	209.2 KB ID:	640151Click image for larger version  Name:	 Views:	1 Size:	271.9 KB ID:	640150
    All in nice parts and bits. wifi a new one I not see before so may be issue with getting other firmware working on it...wifi sits in a special grove placed very well.
    You may only view thumbnails in this gallery. This gallery has 12 photos.
      You may only view thumbnails in this gallery. This gallery has 15 photos.
