Yokatv kb2 pro 3gb/32gb firmware
    Want to share yokatv kb2 pro 3gb / 32gb firmware came from my supplier.
    For people want for backup or manual ota stock firmware.
    https:/mega.nz/#F!KNETBJ5Y!B3Dsly43TqBlJ4p5gqb3Ag
    Usb flashing
    Dow​​​​​​nload and put into usb flash
    flash at your own risk! Dont flash with kb2 2gb ram.
      Thanks..
        I need an update on PC update methods
          Is this Marshmallow, or Nougat?!
            Hi guys, I have the Yoka TV KB2 Pro 3GB 32GB Android 6.0.1 V MHC19J
            20170303.101119 V0923 test keys
            Is there already an Android 7.1 version?
            My play store does not tell me unauthorized device.
            thx
              Hi, does anyone have any idea how I can add contacts? Is this due to Play Store because of the root device?
              Does anyone have an idea how to delete the SuperuserSU completely? I've already tried UPDATE-unSU-signed.zip, but it's not all over and Play Store is causing problems for many apps. Device not authenticated. Can someone help me? Please very important.
                YOKA KB2 Pro 3GB 32GB Android 7.1.1 (20170728) Firmware
                Only 3GB 32GB Pro Version DDR4 RAM
                https://androidtvbox.eu/new-firmware...70728-release/
                Update with free Rashr app from Play Store:
                Rashr app Click >>> Recovery from Memory, load .img File and follow the instruction.
                It works!!!
                _____________________________________
                Important for emergencies: It is best to create a TWRP backup first and mark all the hooks in the backup.
                Create Boot SD Card with Amlogic_SDcardMaker_BootcardMaker_burnBootCard_v1. 0.1
                You need the following files:
                1: BootcardMaker.exe
                2: langu.ini
                3: u-boot.bin
                You need TWRP.img S912 for Android 7.1
                Rename TWRP.img to recovery.img
                Important: Not all SD cards work, no bigger than 16GB, I used an 8GB Sandisk
                SD card:
                1: starts the boat card maker
                2: Selects the SD card at the top.
                3: Hook on partition Yes
                4: Below Open File u-boot.bin
                5: Click Make
                Format Fat 32 done
                Finally, you copy the TWRP file with the new name recovery directly to the SD card just as pure.
                SD card boot:
                Turn off the Yoka KB2 Pro completely, insert the SD card, hold the front button. Turn on the box and when the Yoka logo arrives, wait 5 seconds, slowly count to 5 and then release.
                Good luck.
                  I have just loaded the firmeware for Nouaght 7.1.1 it works OK but it is for a Phone & not for the YOKA KB2 Pro. in you check the info in the APPS settings then then about you will see it is for a phone.???
                  Plus now I can not get rid of it by trying to load the proper firmware from the YOKA KB2 Pro site It won't allow it to load it says it is for the KB2 Pro.
                  So now it is a phone. ?? Does any one no if there is a complete Restore button in side the box. thanks
                    It works!!!
                    2: langu.ini
                    3: u-boot.bin
                    SD card:
                    5: Click Make
                    Format Fat 32 done
                    SD card boot:
                    Good luck.
                    Where can I find the TWRP download link for for Yokatv KB2 Pro. I have been googling and do not know which is the right one.
