Hi Guys, This time we have a windows mini pc to review the NEW Beelink AP34
The Beelink AP34 is a windows 10 mini pc that has an all metal modern looking aluminum case witch also doubles a great heatsink it has the venterlation holes on the bottom and both sides.
Specification
Brand: Beelink
Model: AP34
Type: Mini PC
System: Windows 10
Processor: Apollo Lake N3450
CPU: Apollo Lake N3450
Core: Quad Core
GPU: Intel HD Graphic
RAM: 4G
RAM Type: DDR3
ROM: 64G
Media Supported
Decoder Format: H.264,H.265
Video format: 4K,4K x 2K,ASF,AVC,AVI,DAT,FLV,ISO,MP4,RM,RMVB,RV,TS,VOB,V P9,WMV
Audio format: AAC,AC3,ACC,APE,DDP,DTS,MKA,MP3,MPEG,OGA,OGG,RM,Tr ueHD,WAV,WMA
Photo Format: BMP,GIF,JPEG,JPG,PNG
Support 5.1 Surround Sound Output: Yes
Product Details
5G WiFi: Yes
Bluetooth: Bluetooth4.0
Power Supply: Charge Adapter
Interface: 3.5mm Audio,DC Power Port,HDMI,LAN,Reset Port,SD Card Slot,USB3.0
Language: Multi-language
HDMI Version: 1.4
Other Functions: ISO Files
HDMI Function: HDCP
Power Comsumption: 18W
RJ45 Port Speed: 1000M
Firmware Information
System Bit: 64Bit
WiFi Chip: 802.11ac
Device ports and locations
On the front there's a small power LED.
On the right hand side a Full sized SD card slot & 2 USB3 ports.
On the left hand side is the Movable antenna.
And on the rear is the power button,12v DC input,another USB3 port, HDMI out, LAN,3.5mm Headphones port & a reset button.
The in built heatsink seems to be doing a good job of keeping the unit cool the device does get warm but not anything i would call hot A big pluss is the vents on the bottom and on both sides,i guess the idea is to draw in the cooler air from the bottom and vent it out the sides.
Some internal photos
The beelink AP34 is very well constructed comes pre-installed with licensed 64 bit Windows 10 home so there's no messing around buying & trying to install windows 10.
Now the first boot :-) Windows boots goes through the basic setup EG Country/Region, Language etc etc.It will then ask for the product key (Just skip this)All will be good once fully booted.I then got all the windows updates out the way as i normally do,No problems at all with that now we are running the latest up to date windows 10.
The boot time on the AP34 is fast at around 25 seconds to complete & 4/5 seconds to shut down.
light gaming on the AP34 seems to run ok,Iv tested beach buggy racing set the graphics to high & the game play was perfect, I also tested Ashphalt 8 that played fine too,All games tested was with my tronsmart Mars G01 game pad which connected fine first time no installing drivers etc etc, so some light gaming on the beelink does look good.
AP34 QUICK LOOK Video (ui & games)
Some tech stuff
Crystal disk
Device manager
HWINFO
System
Beelink AP34 Bios
AP34 BIOS Back up
https://mega.nz/#!g8NgRbTT!bMnv2e5jui5Xd5zXrQCMljozyQX3gQwBPPLzAx7 5eXM
1 x Beelink AP34 Mini PC
1 x Power Adapter
2 x HDMI leads
1 x English User Manual
Basic Unboxing Video
More to come
