C8 Player RK3328 1/8GB, 2.4GHZ WiFi, Fast Lan
    Model: C8 Player
    Type: TV Box
    System: Android
    Processor: RK3328
    CPU: Cortex A53
    Core: 1.5GHz
    GPU: Mali-450MP2
    RAM: 1G
    RAM Type: DDR3
    ROM: 8G
    Max. Extended Capacity: 128G
    Decoder Format: H.263,H.264,H.265,HD MPEG4
    Video format: 4K,H.264,H.265,MPEG-1,MPEG-4,VC-1,VP8
    Audio format: AAC,AC3,APE,DDP,DTS,FLAC,HD,MP3,OGG,TrueHD,WAV,WMA
    Photo Format: BMP,JPEG,JPG
    Support 5.1 Surround Sound Output: No
    Bluetooth: Unsupport
    Power Supply: Charge Adapter
    Interface: AV,HDMI,RJ45,SPDIF,TF card,USB 3.1,USB2.0
    Antenna: Yes
    Camera: Without
    Language: English,Multi-language,Simplified Chinese
    DVD Support: No
    HDMI Version: 2.0
    Other Functions: 3D Games,3D Video,ISO Files,Miracast,NTSC,PAL
    External Subtitle Supported: Yes
    HDMI Function: HDCP,HEC
    Power Comsumption: 3W - 5W
    RJ45 Port Speed: 100M
    System Bit: 64Bit
    WiFi Chip: REATEK8189
    System Activation: Yes
    Power Type: External Power Adapter Mode
    Product weight: 0.1000 kg
    Package weight: 0.3600 kg
    Product size (L x W x H): 9.00 x 9.00 x 18.00 cm / 3.54 x 3.54 x 7.09 inches
    Package size (L x W x H): 12.50 x 15.50 x 7.50 cm / 4.92 x 6.1 x 2.95 inches
    Package Contents: 1 x TV Box , 1 x USB Cable, 1 x Remote Control, 1 x Power Adapter
    Gearbest
