CSA93 Android 7, Amlogic S912 64bit Octa Core 3/32GB AC WiFi, Gig Lan BT4.1
    Click image for larger version  Name:	20170331114522_69081.jpg Views:	1 Size:	65.4 KB ID:	641002
    Model: CSA93
    Type: TV Box
    System: Android 7.0
    Processor: Amlogic S912
    CPU: ARM Cortex-A53
    Core: 2.0GHz,Octa Core
    GPU: ARM Mali-T820MP3
    RAM: 2G,3GB
    ROM: 16G,32G
    Max. Extended Capacity: 128G
    TV Box Features: 5G WiFi
    Color: Black
    Decoder Format: H.263,H.264,H.265,HD MPEG4
    Video format: 1080P,3GP,4K,AVI,DAT,FLV,H.264,H.265,MKV,MOV,MP4,M PG,MVC,TS,VP8
    Audio format: AAC,AC3,APE,DTS,FLAC,HD,MP3,OGG,TrueHD,WAV,WMA
    Photo Format: BMP,GIF,JPEG,JPG,PNG
    Support 5.1 Surround Sound Output: No
    5G WiFi: Yes
    WIFI: 802.11 a/b/g/n/ac
    Bluetooth: Bluetooth 4.1
    Power Supply: Charge Adapter
    Interface: AV,DC 5V,HDMI,Micro SD Card Slot,Optical,OTG,SPDIF,USB2.0
    Antenna: Yes
    Camera: Without
    Language: Multi-language
    DVD Support: No
    HDMI Version: 2.0
    Other Functions: 3D Games,3D Video,DLNA,ISO Files,Miracast,NTSC,PAL
    HDMI Function: HDCP
    Power Comsumption: 5 - 10W
    RJ45 Port Speed: 1000M
    System Bit: 64Bit
    WiFi Chip: Q9377
    System Activation: Yes
    Power Type: External Power Adapter Mode
    Product weight: 0.2300 kg
    Package weight: 0.5500 kg
    Product size (L x W x H): 6.00 x 9.00 x 3.00 cm / 2.36 x 3.54 x 1.18 inches
    Package size (L x W x H): 11.00 x 18.00 x 6.00 cm / 4.33 x 7.09 x 2.36 inches
    Package Contents: 1 x TV Box, 1 x Power Adapter, 1 x Remote Controller, 1 x HDMI Cable, 1 x Bilingual Manual in Chinese and English
    Click image for larger version  Name:	20170331114522_94058.jpg Views:	1 Size:	35.6 KB ID:	641003
    Gearbest
    Something old is new again.
    Still Advertised with Android 6 like a few boxes of late some going through the update stage
    Lets see if this has anything to offer
    The Box
    What's in the Box, good looking remote, 2 antennae that's too close looks suss to me.
    The ports and look around, a bit to see, Clock, Power Off button, good to see
    Remove the base not a lot to see here
    Out with PCB
    Closer look
    Gearbest
      A good looking unit, lots of ports, a Clock, Power button, Good looking remote.
      Remote working well and lots of shortcuts on remote for various setup and other apps
      WiFi that appears to be working good and Ethernet
      The Set up Good Google, installed Apps and tests equally as good.
      Temp 45 ~ 65c no troubles
      Root yes, no SU and Upper/Lower Task/Notification bar
      Working pretty smooth bit of zip to it.
      This Model has been around for awhile might get a second lease on life.
      Lets go looking:
      UI and Installed Apps:
      Upper and Lower:
      System Info:
      Root:
      WiFi and Ethernet:
      DRM Info L3:
      Ram and Storage Truth:
      CPU-Z:
      Antutu:
      GeekBench: CPU >
      http://browser.geekbench.com/v4/cpu/5872934
      GeekBench: Compute
      A1SD Bench:
      AIDA64:
      Looking pretty good and the performance is smooth
      Gearbest
          Where can I get a copy of the ROM firmware for this CSA93 device?
            Is there any update for this ROM. I have troubles with this box.
              Did anyone try to use Armbian on this device or can recommend a fitting .dtb or newer Andorid Version? - With root I guess it's just SD Quality for Netflix... I hope it's nice device for Armbian usage.
