Let me first start with that I have successfully un-bricked this device before with a specific ROM and using all of the various methods all over this forum but now none of these will work because, I think, all the partitions on the device are reported by TWRP as being 0MB and "not valid".and so can't be mounted.
As a result TWRP cannot repair or change file system type on the partitions due to it not being able to mount any of them. The usual restore methods of .img and .zip formatted ROMs will not run either.
I have tried the SD boot methods and after the auto run install doesn't work and boots to the recovery, the install methods from the recovery also say they can't mount the partitions.
USB burning tool just reports an error of [0x30201004}UBOOT/Disk Initialise/Send Command/Error Result at 4%.
Yes I have tried different versions,cables, usb ports and images that are supposedly for this box.
Normally this beast can be brought back from the dead quite easily but on this occasion I'm stumped.
Are there any other windows tools etc that can access the box to try and re-partition the NAND ?? because until that happens I think it's fooked.
Cheers in advance of any ideas.
