.gif)
.gif)
This is the test version 1.0 of firmware.
Looking forward to your feedback. Welcome to show your problem![/COLOR]
Email: [email protected]
[email protected]
Current version: SEA1_103MO_16G_20170413
Based on version: SEA1_102MO_16G_20170321
Model: Beelink SEA1
Applicable plate type: RTD1295DD DDR4 2G+eMMC 16G RTL8821AU (wifi + bt)
Please check the configuration version you purchased.
USB upgrade package: SEAI_103M0_16G_20170413
Download link:
https://beelink-my.sharepoint.com/pe...a7bCYOa-u8Dw5E
Current version: SEAI_103M0_32G_20170413
Based on version: SEAI_102M0_32G_20170322
Model: Beelink SEA I
Applicable plate type: RTD1295DD DDR4 2G+eMMC 32G RTL8821AU (wifi + bt)
USB upgrade package: SEAI_103M0_32G_20170413
download link:
https://beelink-my.sharepoint.com/pe...x6UxWvZKJXVdYM
Beelink SEA I Firmware Update Tool Download:
1. Update the firmware and HDCP key tools
2. Only update the firmware tool ,No need to import HDCP key
Link:
https://beelink-my.sharepoint.com/pe...apext3wqzIjURo
Update:
1. Increase hot spot function
2. Default DLNA DRM function
3. Default 25% brightness of LED clock
4. Increase the function of brightness adjusting of LED clock
5. Increase format function
6. Open the test for "Beelive" Home Cloud
7. Increase User Manual
8. Increase the selection of " Only SPDIF output audio"
9. Repair abnormal indication of wired network
10. Repair ADB function
Firmware update tutorial:
1AInstall the software(setup.exe)
2AOpen the software(Launch rtumdfsample.exe)
3AClick 'open' to import firmware
4AInsert USB cable to 'USB 3.0' port on board
5APower on
6AWaiting for burning to 100%SEA I firmware update step, DHCP key update.pdf
