i hope you can help me with my issue. The past days i have tried to install usual Ubuntu or Debian on my MK808 (with rk3066 CPU an rk901 chipset), i tried to install it on the microSD. I searched for some good tutorials on the net, but almost every tutorial i found had some links included that were down, so i could not get the right files etc. pp.
I found out that i basically have to do 2 things: Install a Kernel and put a rootfs on the SD Card. So i thought i could do it like the following way:
1. Take Gallands Kernel from http://hwswbits.blogspot.de/2013/05/...r-picuntu.html and flash it to Recovery Partition using RK Tool / Android Tool v 2.1
2. put Ubuntu rootfs on microSD from: http://cdimage.ubuntu.com/ubuntu-bas...16.04/release/ (The one called ubuntu-base-16.04.2-base-armhf.tar.gz)
But that only gets me the following screen:
Somehow it says unknown partition table. Then close to the end it succeeds to mount it (mounted filesystem with ordered data mode) and the it gets a kernel-panic and shuts down.
I formatted the SD with ext4 and labeled the partition linuxroot.
I also did it with linaro the way Galland described it here: http://hwswbits.blogspot.de/2013/11/...tro-in-sd.html but that gave me the error: Missing /etc/machine-id and /etc is mounted read-only
I didnt want to use Picuntu because i wanted normal ubuntu or debian and i wanted to do it myself and not just flash something
I took the armhf image/rootfs because the rk3066 is a ARMv7 CPU, and that is "armhf" right?
I appreciate every help. Maybe i am totally on the wrong way and you could lead me to the right path
Thanks in advance for your help guys.
- R89
