This is ConvicTech and in this review i' m gonna present you a very useful product from Shenzen Tomato
It is called the One Nuts HD Smart Cable and let's get to it
In the Box
The One Nuts HD Smart Cable comes in a small black box which indicates that it supports 1080p and inside we find the Cable itself and a User's Manual
Pretty basic i can say
Looks & Build Quality
The cable is white and it has three aluminum silver ends
The first end serves as the HDMI Plug
The second end serves as the male USB connection
And the third end serves as the female USB connection
Overall the build quality is ok
Specifications
The One Nuts HD Cable's specs are
Specifications
- CPU: Single Core AM8252
- GPU: 3D GPU 1 x Mali 400
- OS: Linux 3.0.8
- DDR3: 128M
- Flash: 128M
- Miracast: Support
- DLNA: Support
- AirMirror: Support
- Airplay: Support
- System Supported: iOS, Android
- Online & local content wireless display support
- Video/Audio/Photo/Office file/Website
- Office Software Display Presentation
- PDF/MS Word/MS Excel/MS Powerpoint/Keynotes
- Online streaming: Youtube, Netflix, Hulu Plus, IDMB, Quickflix, Family On TV etc
- Online update: Yes
- Support Video Format: AVI/DIVX/MKV/TS/DAT/MPG/MPEG1,2,4/MP4/RM/RMVB/WMV
- Support Audio Format: MP1/MP2/MP3/WMA/OGG/ADPCM-WAV/PCM-WAV/AAC
- Support Photo Format: JPEG/BMP
- HDMI: 1* HDMI 1.4
- DC: 1*Micro USB port
- Support iPhone 5/5S/5C/SE/6/6 Plus/6S/6S Plus/7/7 Plus(iOS 8.0 Above)
- Support iPad Mini/Mini2/Mini3/Mini4/ipad Air/Air 2/iPad Pro
- Support iPod Touch iPod Touch 5th Generation and 6rh Generation
- Support Samsung S3/S4/S5/S6/S7/Note3/Note4/Note5
- Support Huawei P8/P9
- Support Others TV/Moniter/Projector/Computer
The installation and setup is pretty straightforward
Although according to the product's specifications only Samsung, Apple and Huawei devices are supported, i was able to make it work with absolutely no problem using my Xiaomi phone but strangely enough when i connected it to my Sony Xperia Z3 Tablet compact, even though i was able to get picture, i wasn't able to run kodi or some games
I don't know if that's a problem that can be fixed with a future update but keep it in mind
Now as for the setup
You just connect the cable to the HDMI Port of your TV, then connect your smartphone or tablet using a USB to MicroUSB cable via the cable's USB 3.0 port and then connect the cable's USB to the USB Port of your TV in order to power it up and charge your device at the same time
Pretty simple wasn't it?
Usability
Now since the cable is plug and play, it means that as soon as you make the connection you' ll be ready to broadcast your smartphone's content on your TV
So you ' ll be able to view your photos, browse the Web, watch youtube videos and movies on the big screen
You can also do it with some games too
Conclusion
The One Nuts HD Smart Cable is a great way to project your smartphone's or tablet's content on your TV giving you the pleasure to enjoy everything on the big screen
It's low price and very good build quality make it a must have gadget which will give you tons of entertainment and fun
Pros
- Build Quality
- Price
- Very easy installation
- Plug n' Play
Cons
- The Cable could be a little bit longer
- Can't run Kodi on some unsupported devices
Watch my Video Review
Review English
Review Greek
I hope you liked my review, stay tuned for more and as always for more unboxings, reviews and tutorials subscribe, share and follow me:
Youtube
Google Plus
