Mecool bb2 pro Android TV 7.1
MurtiE
thank you very much for being kind and clear. I will try Tomorrow....too bad that the Russians do not speak and write English....
[update 22 october 2017]
I have flashed the ROM but when I press the reset button and plug-in the power I go in the system recover of Android and no in TWRP. I have tried to flash again but the result is the same. In my last ROM of Superceloron the TWRP recovery was installed. The ROM installs the TWRP or I need to copy the file recovery.img on the SD card?
[update 23 October 2017]
this rom is awesome! fast with a lower cpu temperatureLast edited by cappoccia; 10-23-2017, 16:16.
neutester I have flashed again the ROM, but also I have copied in the root of the SD card the file recovery.image so I don't know if has worked the second flash or an automatic installation of the recovery via SD card. You can also trie to flash again the rom ad after you don't have to load adndroid, but power down the device e after bootup first in to recovery to prevent android overwrite the recovery. This tip work also on mobile phones.
MurtiE Yes, I've flashed the rom and after restore Vasily's backup. It's great! thanks for you help.
Or alternatively, maybe someone with the know-how could convert the latest 20171101 OTA (Android TV rom) to the .img Burn Tool format?
Where was this latest rom 20171101 OTA (Android TV rom) posted, is it official ?
You can flash image from
Rom v3 works good, but a newbie is very hard to understand the process. I want to make i guide, if i will write a guide to flash vasily rom?Last edited by Edoardo001; 01-05-2018, 22:10.
Many ported firmwares to pick from ....
http://www.microsofttranslator.com/b...98%26st%3D8120
Currently using `H96 Pro aml_7.1_s912_q9377-S912-XGO_mac-20180409 (Androidx64)`
Originally posted by nareshkumar1985 View Post
Thank's
There are currently 3051 users online. 6 members and 3045 guests.
