ZIDOO X10 Android 6.0 RTD1295 2G/16G SATA AC WIFI Gig Lan USB3.0 BT4
    Brand: ZIDOO
    Model: X10
    Type: TV Box
    System: Android 6.0
    Processor: Realtek RTD1295
    CPU: Cortex A53
    Core: Quad Core
    GPU: Mali-T820MP3
    RAM: 2G
    RAM Type: DDR3
    ROM: 16G
    Max. Extended Capacity: 32G
    TV Box Features: 5G WiFi
    Decoder Format: H.263,H.264,H.265,HD MPEG4
    Video format: 4K,H.264,H.265,VP9
    Audio format: HD
    Photo Format: BMP,GIF,JPEG,PNG,TIFF
    Support 5.1 Surround Sound Output: Yes
    5G WiFi: Yes
    Bluetooth: Bluetooth4.0
    Power Supply: Charge Adapter
    Interface: TF card,USB2.0,USB3.0
    Antenna: Yes
    Camera: Without
    Language: Multi-language
    DVD Support: No
    HDMI Version: 2.0
    Other Functions: 3D Games,3D Video,Airplay,DLNA,ISO Files,Miracast,NTSC,PAL
    External Subtitle Supported: Yes
    HDMI Function: CEC,HDCP
    Power Comsumption: 12V 3A
    RJ45 Port Speed: 1000Mbps
    System Bit: 64Bit
    WiFi Chip: RTK8821
    System Activation: Yes
    Power Type: External Power Adapter Mode
    Product weight: 1.8600 kg
    Package weight: 1.8800 kg
    Product size (L x W x H): 19.70 x 19.70 x 6.50 cm / 7.76 x 7.76 x 2.56 inches
    Package size (L x W x H): 31.30 x 25.50 x 8.50 cm / 12.32 x 10.04 x 3.35 inches
    Package Contents: 1 x TV Box, 1 x Remote Control, 1 x HDMI Cable, 1 x Power Adapter, 1 x User Manual, 1 x Standard AV Cable
    Gearbest
    Today's A look at the ZIDOO X10 and what makes it happen.
    Huge Box and Packed very well as you will see.
    Packing
    More Packing
    The Bits in the Box
    The Main Bit In the Box
    Topside view Looks Pretty Good
    All the Bits form the Box and the Remote is Backlit
    Front, Great Display
    Back, Plenty of ports here
    Side Door, Sata Drive Caddy
    Bit of Look see no one home as yet
    More Ports,
    A look on the Inside
    Closer look and no it was scratched when i got there.
    Sata Caddy
    Close up of the Back of Display
    Good looking unit, performs as well as a X9S i reviewed earlier.
    More to come
    Thanks You Gearbest and DHL for speedy Delivery
      Here i have it Hooked up to what at first I was a bit Suss about, this can't be Bluetooth Speaker it's Half a can of Beer gone wrong....
      Well that certainly surprised me, Sounds Excellent. easy, very easy to use,.
      Well it is a Xioami so I sorta had a feeling it would be good and it is.
      Click image for larger version  Name:	1459319594297256.jpg Views:	1 Size:	26.7 KB ID:	647969
      Click image for larger versionName:	1459321286663716.jpgViews:	1Size:	51.9 KBID:	647968
        Still having a good fiddle with this Unit Zidoo and it is very interesting device and a nice bit of Shelf furniture for sure
        Ziddo website have a neat flow thru of all the features of the Zidoo x10
        Lots of Pictures with the Information
        Have a look HERE > Zidoo
        I will be putting it to the test soon with Benchmarks and Information soon
          A bit of a firmware update today.....Will start a few Benchtest to see how it performs,
            UI Much the same
            Thought they may have gone for a bit different look than the x9s to give that little more WOW factor.
              Some Of the quick settings menu options should keep the avid enthusiast happy lots of settings to tweak and twerk.
                After a hard day of Bench Testing
                One must relax with some wine (Beer) and music to ease into the evening and what better ways than some something Loud and looks very bodacious.
                A variety of connection ways: supporting Bluetooth, dual-band WiFi, DLNA, QPlay, APP, AUX audio, U disk and to connect your phone, tablet PC or other digital devices
                Built-in 8GB memory: built-in 8GB memory space and USB storage expansion, you can download or copy the music to the sound box.
                Even if no network, you can still play good music offline
                4 voice units, pure voice quality: equipped with powerful speaker units, and adopts inverter type of technology, make the voice sound better
                Be Honest no idea what I am doing with this speaker as yet,
                Bluetooth works very well well, can do a heap of other things that I must translate.
                Sounds is excellent like previous Mi Speaker tested,
                BIG Sound only takes up small amount of space as compared to a sound bar etc.
                Gearbest
