Mini M8S PRO Amlogic 912 android 6 3/32GB Dual WiFi, Gig LAn BT4
    Model: Mini M8S PRO
    Type: TV Box
    System: Android 6.0
    Processor: Amlogic S912
    CPU: Cortex A53
    Core: Octa Core
    GPU: ARM Mali-T820MP3
    RAM: 3GB
    RAM Type: DDR4
    ROM: 32G
    Max. Extended Capacity: 32G
    TV Box Features: 5G WiFi
    Decoder Format: H.263,H.264,H.265,HD MPEG4
    Video format: 4K,AVI,DAT,ISO,MKV,MP4,MPEG,RM,WMV
    Audio format: AAC,DTS,FLAC,MP3,OGG,RM,TrueHD,WMA
    Photo Format: BMP,GIF,JPEG,JPG,PNG,TIFF
    Support 5.1 Surround Sound Output: Yes
    5G WiFi: Yes
    Bluetooth: Bluetooth4.0
    Power Supply: Charge Adapter
    Interface: DC Power Port,HDMI,RJ45,SPDIF,TF card,USB2.0
    Antenna: Yes
    Camera: Without
    Language: Multi-language
    DVD Support: No
    HDMI Version: 2.0
    Other Functions: DLNA,ISO Files,Miracast
    External Subtitle Supported: Yes
    HDMI Function: CEC
    Power Comsumption: 6W
    RJ45 Port Speed: 1000M
    System Bit: 64Bit
    WiFi Chip: 9377
    Power Type: External Power Adapter Mode
    Product weight: 0.0900 kg
    Package weight: 0.1200 kg
    Product size (L x W x H): 11.00 x 11.00 x 1.75 cm / 4.33 x 4.33 x 0.69 inches
    Package size (L x W x H): 16.00 x 16.00 x 4.00 cm / 6.3 x 6.3 x 1.57 inches
    Package Contents: 1 x Mini M8S PRO TV Box, 1 x Power Adapter, 1 x Remote Control, 1 x HDMI Cable
ID:	642457Click image for larger version
    Gearbest
    Today we can have a look at the Mini M8S PRO Amlogic 912 android 6 3/32GB Dual WiFi, Gig Lan BT4
    Simple looking unit not a lot of Ventilation going on
    Amlogic 912 3/32Gb of Ram
      A few bench tests a bit of information
      I do like the UI a Windows feel and quick short cuts on home screen to get to some hardware setting, WiFi, BT, Sound etc.
      Performance looks ok Surprised runs pretty cool considering no vents must be that hunk of metal and thermal pad working well and not tin lids keeping the heat in.
      Box performs well and do like what I am seeing WiFi and ether net speeds Ok and as test below show not to bad Performance wise.
      had an update as soon as unit was powered up so all went well.
      Unit was installed with Qodi, not any more...and not much other Junk
      Installed an Older Netflix V4 working ok at present and the Unit does have Root
      You can see what's going on with screen caps below. and a bit of a video at the end of the UI and Boot
      A quick Video of the UI and boot and an attempt to boot like Windows
      Gearbest
        Hello
        thank you for this information, )'m very interested
        [ROM] Beelink GT1 Ultimate SCV2-ATV (Android TV) (DDR4)
        This rom is compatible with the mini m8s pro s912 3g/32g for ANDROID TV ?
        cordially
          This is 100% ok ! : http://www.bee-link.com/Beelink-13895-1-1.html
            Originally posted by gatos814 View Post
            Are you sure, What is the goodness of this rom compare to the original one ?
            i see here that it have a update to nougat 7.1.2
            Also because i don't have my box (awaiting for it) does it is a "Android TV BOX" or a "Android Box" because i want to use hyperspin and other app that is only compatible with certified android TV Box.
              I had in my hands a few days before one 2/16 and one 2/32 with both Android 7
              I downgrade them to Android 6 with BEELINK GT1_113M0 and they working 100% ok even with the remote!!
              So i suppose this 3/32 version is exactly like the GT1 ultimate!
              Regards...
                ok, thanks,
                do i need to downgrade it to GT1_113M0 before flash GT1_113M0_TVStock-20170606.img (android TV) or should i go directly with android tv ?
                  ok, thanks,
                  I don't know m8!
                  Try it and if it's not work use GT1_113M0 standard !
                  Good luck!
                    I don't know m8!
                    Good luck!
                    thanks, it works. directly.
                      Ugh, no WideVine L1 so no go
                        Hello, gentlemen!
                        How can I flash m8s pro 2/16 with firmware from Ugoos am3? I have only Linux laptop.
                        Hope it is proper question for this topic..
                          Hello
                          Any custom Google TV for this one ?
                          Like the great ones from Magendanz ?
                            Instale esta room en mi TV box ms8 pro y trabaja bien lo único es que no funciona el Internet por cable y el control remoto como puedo solucionar este problema
                              Hello ppl,i received this box and have to say i am 90% pelased with it.
                              I have a small problem with it while watching IPTV.
                              Boc is connected to TV through HDMI cable (oh,well...) and whenever i change channel or pause and play channel or stop a channel,sound from tv's speakers is having a small blast (the sound that is produced whenever you plug in anything to an amplifier,that small "boop")
                              Is that normal happening?
                              It is not a big deal,but happens everytime i do one of the actions mentioned...
                              If anyone can help me would be great.
                              Thanks.
                              PS: do you recommend me changing rom to the box? It is updated to the last one from factory..
