What are hidden gems android apps?
YouTube (old version...without ads/ restrictions watching)
andftp (old version without ads , its a ftp client)
Free ftp server ( found at F-droid - ftp server that only activates when connected to known WiFi networks, non default port)
Ms word ( old version, No need to login to 360 to edit doc)
androidtuner (must tweak everything)
adaway (must remove ads)
Netguard ( found at f-droid : Firewall...to allow or not allow sorten apps to connect to the web)
Day & night live wallpaper ( paid : just eye candy)
Ezpdf ( paid: wort the money..)
Usb audio player pro ( paid: hear radio / files / etc with the best quality using USB DAC )
jetaudio plus (paid: if you phone has flat audio...DSP brings new life )
petrus reboot ( quickly reboot to recovery/ trrw / etc)
spmc ( works on most systems better then off.kodi )
AINUR Audio ( found at xda : if your device/Os supports it)
viper4android ( if supported by Os)
LBA security ( is a great tools..eng version is on xda)
IYBP (YouTube player without ads / up to 2160p / with spoof option to enable HDR , to be found on XDA forum )
Galaxy ( found on XDA it's a alternative Google market with spoof function, no more incompatible with your device msg )
Netflix app ( found on XDA its Netflix with HDR enabled)
tubi.TV ( it has some nice collection of TV movies, does have some ads )
total commander (amazing file utility with dual view and root function )
screen lock time password ( use current time as login password )
sentio desktop (get a laucher that like ms windows, windowed apps if android 7+ )
CPU throttling test ( is your device properly cooled? or throttling )
Greenify (it hibernates apps So longer battery life )
disableservice (if you have root and wish more controls of some apps )
note: 4k req: hdcp 2.2 and youtube HDR req: hdcp 2..2 , DRM1 and HDR compatible TV/monitor (and spoof as galaxy s8)
There are currently 2618 users online. 0 members and 2618 guests.
