THL TV Box Amlogic 905x 1/8GB, 2/16 2.4GHZ WiFi Fast Lan
    Brand: Thl
    Model: Box 1
    Type: TV Box
    System: Android 6.0
    Processor: S905X
    CPU: Cortex A53
    Core: Quad Core
    GPU: Mali-450
    RAM: 1G or 2g
    RAM Type: DDR3
    ROM: 8G or 16G
    Max. Extended Capacity: 128G
    Decoder Format: H.263,H.264,H.265,HD MPEG4
    Video format: 4K,AVI,MKV,MP4
    Audio format: MP3,WAV
    Photo Format: BMP,GIF,JPEG,PNG
    Support 5.1 Surround Sound Output: No
    5G WiFi: No
    Bluetooth: Unsupport
    Power Supply: Charge Adapter
    Interface: AV,DC Power Port,HDMI,RJ45,TF card,USB2.0
    Antenna: No
    Camera: Without
    Language: English,Germany,Japanese,Korean,Simplified Chinese
    DVD Support: No
    HDMI Version: 1.4
    Other Functions: DLNA,Miracast
    HDMI Function: CEC
    Power Comsumption: 10W
    RJ45 Port Speed: 100M
    System Bit: 32Bit
    WiFi Chip: RTL8189
    System Activation: Yes
    Power Type: External Power Adapter Mode
    Product weight: 0.1980 kg
    Package weight: 0.6150 kg
    Product size (L x W x H): 10.50 x 10.50 x 2.00 cm / 4.13 x 4.13 x 0.79 inches
    Package size (L x W x H): 17.60 x 13.50 x 7.70 cm / 6.93 x 5.31 x 3.03 inches
    Package Contents: 1 x TV Box, 1 x HDMI Cable, 1 x English User Manual, 1 x Remote Control
    Gearbest
    Hi ,
    i thought they make only Handys .
    Greetings
    gefattern
      Today we can have a closer look at THL TV Box Amlogic 905x 2/16 2.4GHZ WiFi Fast Lan
      Thanks to Gearbest for the opportunity to show and tell,
      Seems the complete package Ac Wifi BT 2/16
      Lets have a look
      The Box, the recycled look
      What's in the Box
      Front Display
      Side Ports
      Bacl Ports
      Underneath No vents.
      Under side of PCB
      Click for bigger
      Top Side PCB
      Click for bigger
      Using weight block as heat sink Excellent Idea
        A good looking , inners look ok and now for some testing to see how it performs
        To get things started a quick Video of Of startup and UI ..etc
          A Closer look into the testing
          Remote feels ok rubberised finish...works, Buttons a bit clunky or nor positive when pushed.
          Startup all Good no problems with sign in to Google etc
          Some apps fail to run in fullscreen,
          No Upper or Lower Notification or Task bar, and No Root
          Temps are ok looking screen monitoring all runs fairly smooth.
          Ram speed a little slowish as you will see, better (faster) ram would make for a better box
          Wifi to be OK as with Ethernet no trouble here.
          Only a few quirky things. Rom is couple months old so must due for an update, no OTA as yet.
          Onto the Info:
          UI and System Info
          TV Centre Kodi 17.1
          DRM Info
          Ram and Storage Truth
          Vellamo
          Geekbench, CPU and Compute
          More Info > http://browser.geekbench.com/v4/cpu/3833233
          CPU-Z
          A1SD
          TC Centre (kodi 17.1)
          YT 1080 ok
          Hope for an update soon,
          One of the better out of the box experience, all just about works and that has to be good.
            hello,
            i bought the thl tv box pro (2gb version), i would like update to android 7.1 but i didnt find any firmware for this tv box. Can somebody give me a link for the fimrware (android 7.1) or a compatible custom rom ?
            br,
            skycrow67
            i tried, its over 1 week, no answer -.-
            br
