U5 PVR Deluxe Android Media Player 2/16GB AC WiFi Gig Lan & DVB
    CPU : ARM Cortex A53,Hi3798CV200 Quad core 64bit, GPU : High-performance multi-core Mail T720
    Storage Memory : 16GB eMMC 5.0, System Memory : 2 GByte, DDR4-2133 SDRAM
    MPEG Transport Stream A/V Decoding, Transport Stream : ITU-T H.265/HEVC & H.264, ISO/IEC 13818-2 MPEG-2 AVS&AVS+,VC1, VP6, VP8, VP9
    Click image for larger version  Name:	IMG_2760.jpg Views:	1 Size:	113.4 KB ID:	643696
    Click image for larger version  Name:	IMG_2761.jpg Views:	1 Size:	97.3 KB ID:	643697
    Click image for larger version  Name:	IMG_2762.jpg Views:	1 Size:	106.6 KB ID:	643698
    Click image for larger version  Name:	IMG_2764.jpg Views:	1 Size:	97.1 KB ID:	643699
    Click image for larger version  Name:	IMG_2768.jpg Views:	1 Size:	137.0 KB ID:	643700
    Click image for larger version  Name:	SSD HDD_Installation_1 .JPG Views:	1 Size:	98.8 KB ID:	643701
    Click image for larger version  Name:	SSD HDD_Installation_2.JPG Views:	1 Size:	120.1 KB ID:	643703
    Power Supply
    Input Voltage : AC 90 ~ 250V, 50/60HZ
    Output Voltage :12Vdc / 3.0A
    Type : External AC to DC Adaptor
    Power Consumption(Watt) : Operation Mode : T.B.D / Stand-by Mode : Under 0.5W
    Physical Dimension
    Size(WxDxH) : 275mm X 320mm X 135mm
    Net Weight : 1.8 Kg
    Operating Temperature : 0 ~ 45℃
    Storage Temperature : -10 ~ 70℃
    SW spec
    OS Android : 5.1.1 Lollipop
    Live TV app : Customized Live TV App
    DVB Support : Customized TVHeadEnd 3.6
    Today we are going to start to have a look at the U5 PVR Deluxe Android Media Player 2/16GB AC WiFi Gig Lan & DVB
    I first stumbled across this box with some writings at Eddy LAB back in March (translators on) interesting and peaked my interest.
    Still need to get my Head around TVHeadend and the Linux side of the deal, looks interesting
    Based on the Hisilicon v200 and they just have the goods when it comes to video Display.
    Its got Vents lots of vents this is a cool player and it can do so much.
    Does TV excellent, (my opinion) one of the better DVB-T interfaces I have used.
    The Box looks and is meaty, Its has Sata for PVR, USB 3, AC WIFI and Gig lan, USB 2, Spdif, AV,
    Runs TVHeadend Linux and Android,
    A remote that I find easy to use. Beefy 12v 3amp {power pack}
    You have a selection of tuners be it Twin or Single see below
    Smart Card Slot,
    Spec
    HiSilicon Hi3798C V200 quad-core 64-bit ARM Cortex-A53 CPU up to 2.0 ARM Mali-T720 GPU
    DDR4 2GB, EMMC 16GB, Internal Sata (not supplied)
    Android 5.1 x (support Linux booting support)
    Android TV OS(ATV) Custom FW (V1.0)
    Android OS and Linux (Debian) OS at the same time booting in U5PVR (Change feature)
    Android TV OS & Linux simultaneously (Dual OS)
    Linux runs in the background on the Android OS base.
    You can connect to SSH to deposit the Linux server (U5PVR)
    A runnable Linux Server Feature
    A. Next Cloud - File share Server (Remove from default)
    B. Plex Media Server (default)
    C. Transmitton Server (default)
    D. TVHeadend Server #2 (default)
    E. SSH Server (default)
    F. FTP Server (default)
    AC Wifi, BT4, 10/100/1000 Lan
    Tuner Options
    (1) For ATSC(Terrestrial) : ATSC 2.0 1EA + ATSC 2.0 1EA
    (2) For DVB : DVB T2 1EA + DVB S2 1EA or DVB T2 1EA + DVB T2 1EA
    or DVB S2 1EA + DVB S2 1EA
    (2-1) Smart card reader support (DVB S2)
    USB 3.0 1EA, USB 2.0 3EA, Optical Audio 1EA
    RCA : Support by 4 Pin RCA cable
    What in the Box
    IR Remote control
    Power Adaptor
    Manual
    WiFi ANT
    Internal SATA connector
    Lets have a look see:
    Huge Box Plenty of packing inside
    Whats in the Box and Looks Great
    Front and that Display, note small Gap around top as does pop off for easy mounting of HDD and that gap is added Ventilation
    Back
    Side with Wifi Connector and Vents
    Other Side Card Slot and USB Ports and Vents
    Under side Oh notice the Vents
    Top side with easy pop/lifts off lid, mounting Slots 2.5/3.5 HDD, Note Fan slots option BUT running 12+ hours a day No heat
    Under side Lid and its easy to pop top Mounts
    Removal of top tray to mount HDD easy.
    Power Pack
    Closer look at the inners
    Sata and eMMC Samsung KLMAG2GEND-B031 eMMC 5.0
    Ram- K4A8G16-5WG8CRC DDR4
    Wifi-AP6335 802.11 b/g/n/ac with Bluetooth 4.0
    PHYceivers › 10/100/1000M Gigabit Ethernet
    GL850G Genesys Logic's Universal Serial Bus
    More to come
      Just a few quick test/Info about the U5 PVR Deluxe Android Media Player 2/16GB AC WiFi Gig Lan & DVB
      Standard ATV UI
      ATV Settings much the same
      More settings
      Ram and Storage Truth
      No DRM at Present but being worked on
      A1SD Bench
      Vellamo
      Available in the Following Configuration
        Looks very interesting, but still no CI+ interface for watching coded packages.
          To install Hdd very simple as seen in the Following Images from U5 support website
          Lid as mentions easily Lifts or Pops of.
          Click image for larger version  Name:	2.jpg Views:	1 Size:	409.3 KB ID:	648453
          Grab Sata and Power cable and Plug in PCB
          Click image for larger version  Name:	2a.jpg Views:	1 Size:	119.9 KB ID:	648451
          Easy as
          Click image for larger version  Name:	3.jpg Views:	1 Size:	75.7 KB ID:	648449
          Now Mount You HDD: 3.5in Use B slots or A and C for 2.5
          Click image for larger version  Name:	4.jpg Views:	1 Size:	76.9 KB ID:	648450
          Once mounted add cable to HDD
          Click image for larger version  Name:	5.jpg Views:	1 Size:	59.3 KB ID:	648452
          Screw inner Lid back on job is done.
          Click image for larger version  Name:	6.jpg Views:	1 Size:	55.3 KB ID:	648454
          Pop the outer lid back in place.
          Click image for larger version  Name:	7.jpg Views:	1 Size:	287.0 KB ID:	648455
            Is the satellite tuner sensitive or poor as the KIII Pro? thank you Click image for larger version  Name:	1.png Views:	1 Size:	241.0 KB ID:	652411
              Sorry dont have Sats here to test
              A Good question to ask in their Forum on sensitivity and selectivity,
              Yes the Alignment of some of the ports is a little of, first release/demo
              Now it's now sold under the Vontar brand, looks like a production issue ports works fine.
              Be Nice if it had a Egreat/Himedia/Zidoo display, current display works as is but needs some luv.
                I asked on their forums, they replied that it's like the U4PVR, but that they always test it without satellite tuner worries me !.
                  Ok yes, i have also asked in another group about your question.....
                  Maybe just Google around and see if any sat forums make mention..may be lucky.
                    This looks like a nice box.
                    Have you managed to use any of the PVR funtionality yet?
                      Well yes record to HDD etc easy ...like most and time function etc...
                        From ATV5.1 to ATV 7 or from ATV7 to ATV5.1
                        U5PVR Transformation Image
                        This image will update from ATV 5.1 to ATV 7.0 or from ATV 7.0 to ATV 5.1
                        ATV7 ==> ATV5.1 : https://drive.google.com/open?id=0B9...VpJMGhxcEJsRjA
                        ATV5.1 ==> ATV7 : https://drive.google.com/open?id=0B9...VlUQ2Vpc0tHaHM
                        Beta:
                        Source: U5Blog
