MXQ HF10 Digital TV Box 1/8GB 2.4GHz WiFi, Fast Lan BT4.2
    Brand: MXQ
    Model: HF10
    Type: TV Box
    System: Android 6.0
    Processor: S905X
    CPU: Amlogic S905X,ARM Cortex-A53
    Core: 1.5GHz,Quad Core
    GPU: Mali-450
    RAM: 1G
    RAM Type: DDR3
    ROM: 8G
    Max. Extended Capacity: 128G
    Color: Black,White
    Decoder Format: H.263,H.264,H.265,HD MPEG4
    Video format: AVC,DIVX,H.265,MPEG1,MPEG2,MPEG4,RM,RMVB,VC-1
    Audio format: AAC,APE,DDP,FLAC,HD,MP3,OGG,TrueHD,WAV,WMA
    Photo Format: BMP,GIF,JPEG,JPG,PNG,TIFF
    Support 5.1 Surround Sound Output: No
    5G WiFi: No
    WIFI: 802.11 a/b/g/n/
    Bluetooth: Bluetooth4.
    Power Supply: Charge Adapter
    Interface: DC Power Port,HDMI,RJ45,SD Card Slot
    Antenna: No
    Camera: Without
    Language: English,French,Germany,Italian,Multi-language,Simplified Chinese
    DVD Support: No
    HDMI Version: 2.0
    Other Functions: 3D Games,3D Video,ISO Files,NTSC,PAL
    External Subtitle Supported: Yes
    HDMI Function: CEC
    Power Consumption: 18W
    RJ45 Port Speed: 100M
    System Bit: 32B
    System Activation: Yes
    Power Type: External Power Adapter Mode
    Product weight: 0.5700 kg
    Package weight: 1.0500 kg
    Product size (L x W x H): 9.10 x 9.10 x 12.80 cm / 3.58 x 3.58 x 5.04 inches
    Package size (L x W x H): 18.00 x 11.00 x 18.00 cm / 7.09 x 4.33 x 7.09 inches
    Package Contents: 1 x TV Box, 1 x Power Adapter, 1 x Remote Control, 1 x HDMI Cable, 1 x English User Man
    Gearbest
    A short Video From armdevices.net
      Well its taken a while for this to appear, finally has, thanks to Gearbest.
      Today we have a bit of an unusual unit...
      Its not a Nuclear Reactors Cooling Tower
      But I think it has a bit of an identity crisis, not sure what it can be, is or do
      We have a MXQ, HF10, Android 6.0, S905X Amlogic S905X,ARM Cortex-A53 1/8GB, Dual WiFi, BT4 and BT Remote for Audio/Mike
      Its Part Amazon Alexa and a Typical Andorid 905x 1/8, also a BT Speaker when HDMI removed from TV/Box
      More on that Later
      Lets have a look
      The Box, bit of a rough journey I think.
      What's in the Box.
      The Look around
      Base Of, Not to sure how good the thermal pad will work against the plastic base, its the thought that counts i guess.
      What you see Closer
      Other side, Heat sink
      Heat sink Removed
      To remove PCB lucky a Connector, and all sorts of cables for IR and Touch Controls etc
      Light Show Out Front
      Bit of a Glow
        As mentioned a 1/8GB Android 905X Media Player, typical speed and performance reflects the Hardware that it has.
        It's also a Blue tooth speaker and the sound is Good, solid enough to have the missus saying turn it down, (Best test ever).
        BT remote that you can chat to Alexa (there own cut down MXQ Alexa I feel)
        No integration as yet with Netflix, and other Installed apps on this Unit.
        First need to log in or create an Amazon account to use.
        Chat away asking for world events and weather etc, try and play music or interacting with apps installed,
        Nope, advises has no skills attached and needs to set up in Alexa App/Login etc, or Amazon Music is not supported by this device,
        Maybe it did not work out well with Amazon and could not get it approved/certified, may be still happening ?
        As Amazon have their own range, maybe they don't want to share, Our Alexa, Our Box show us the money
        The MXQ Alexa app installed has no settings , and the r
        eal version of Alexa app will not Run on this Player.
        Still looking to see if there is a solution, when time permits.
        Once the unit is fired up you can pair the speaker with your phone etc, music/audio plays on TV.
        No option found on how to divert to speaker only, need to unplug HDMI cable then speaker becomes stand alone device.
        Then there is no Visual indication on speaker that you are Asking or Pairing, is Alexa is Thinking or Listening.
        So If you're feeling alone, you can stream your music to the Speaker and have a chat to Alexa and ask the hard questions.
        Being an Amazon thing this player needs to be more amazon friendly to work with Alexa 100%
        Anyway lets have a look at some information and a few Benchmarks etc.
        First Run setup
        UI
        Android 6 System and their own
        DRM Info
        Ram and Storage Truth
        CPU-Z
        Temps 50 ~ 60c
        Geekbench CPU
        More Info >
        http://browser.geekbench.com/v4/cpu/4733739
        Geekbench Compute
        Kodi 17.5 installed
        The Alexa App: You can push the mike at anytime and ask.
        A1 SD Bench
        It works Fair for what it is,
        WiFi and Ethernet Ok, set up all good with Google and installed apps etc, bit slow when pushed 1/8 units are ok but can lag.
        Netflix in its 480 display watchable, as YT 1080 looked.
        This unit had a dud power pack putting out 20v pulsing so some circuit protection by the looks, just as well
        Or the Nuclear looking Cooling Tower might have blown up...that would have been a good photo to see.
