[ROM] Beelink GT1 Ultimate Nano & TVStock (Android TV) Nexus ROM
Guest
Originally posted by minonano View Post
Guest
Originally posted by minonano View PostAlso are you getting any video?
You could try opening the box and hook up serial console.
open the for example putty software and check the log.
also one you get the UART to work you could hold space when biotin the unit cinect the box to PC. When in uboot type update this will force the upgrade mode and you could upgrade using .IMG and burn tool on PC.
Everything is possible if we work together!
Originally posted by lewy20041 View PostYou could try opening the box and hook up serial console.
Originally posted by GNex5 View PostIf a factory firmware flash is what bricked the box, would Beelink replace the product under its warranty? It probably won't be a quick process as Magendanz is in the USA and Beelink is in China but maybe it's worth considering.
Guest
Originally posted by minonano View PostI agree, any suggestions in how to proceed?
Usually this would be no big deal, and I'd short two pins to enter Mask ROM Mode and be back up and running in a few minutes, but the FBGA package makes shorting pins much more difficult and you can't just reference the pinout for the eMMC chip. (With ball grid arrays, all pins are sandwiched between the chip and the PCB.)
At least I got one release completed before hitting all stop, but I'd really hoped to do more.
Originally posted by Magendanz View PostI feel bad because this is the first piece of hardware that had been donated to me by GearBest for custom ROM development. Generally, I take much better care of my hardware, and this is the first box I hadn't been able to revive after being "bricked" by a bad ROM flash. The irony is that it was the official Beelink 311M0 ROM posted on their forum that caused the blank screen on boot. Reverting back from the 312M0 build was just a troubleshooting effort on my part to work around the occasional hangs we were seeing, and it seems likely the newer hardware was incompatible with that release.
There are currently 2918 users online. 1 members and 2917 guests.
