By "working" I mean the video and audio input working. If anyone with a working skype+camera setting could post their webcam model and which firmware they're using, it'll help a lot. I couldn't really find a definitive list of compatible devices..
mk908 which webcams are known to work?
I see on geekbuying that logitech c170 works with mk908. Not sure which firmware geekbuy tested with.. but I'm trying to get a working skype setup, and not sure which webcam to buy. C170 seems okay, but ideally I'd be able to go 720p since I don't really want to spend money on a low end device. (in case I don't end up using it with mk908)
By "working" I mean the video and audio input working. If anyone with a working skype+camera setting could post their webcam model and which firmware they're using, it'll help a lot. I couldn't really find a definitive list of compatible devices..Tags: None
Originally posted by kensuguro View Postwhich rom are you on?
Hmm, that was fun. Sadly, reboot to bootloader does not actually work in Finless 1.5 rom. It reboots to recovery instead. That's unfortunate, because there is also a reboot to recovery option, which also reboots to recovery. Anyway, I was able to use the hardware button to get into the bootloader. The hardware button is garbage. It's really hard to press even with the unit de-cased. At least I was able to remove the case with my thumbnails.
OK, I can now verify that it works on stock, too
There are currently 3151 users online. 0 members and 3151 guests.
