Ematic EGM002 can it be rooted? CM rom?
Hi guy's (and gals) seems like this is one of the better forums in regards to Ematic tabs. I just bought a EGM002 ($39.99 **** daily deal) cant find any info on it anywhere. I do know its a 7in capacitive android 4.1 jellybean tab with 1ghz proc and 400mhz gpu front facing camera with 4gb storage and 512 ram. It does have a MicroSD slot. I've seen some ematic roms that seem to be possibly universal to a capacitive ematic 7inch tab but not sure. Any thoughts would be extremely grateful. ThanksTags: None
If you want to try anything first make sure you contact ematic at http://www.ematic.us/ and ask them for the official rom so that if the custom one doesn't work you can just reverse what you did. If you decide to do that I can help you with the rooting. I tried rooting mine but it doesn't seem to work with my tablet even though it's specifically for it. The touch screen wouldn't work and the flash was on the whole time. For now you're stuck with http://www.androiddrawer.com/ or another site that hosts free versions of different apps and games and also pirating . You can also play gbc and gba games on it which isn't too bad.
There are currently 3863 users online. 0 members and 3863 guests.
