I'm looking to get a replacement power supply for a S95 Meta, but not sure exactly what I need. I've tried with a USB 2A barrel cable that fits into a USB power adapter, and the blue light comes on, but nothing else - no picture. I realise it says 5V 3A on the back of the box, although cheaper boxes I've had work fine with 2A with the same power supply and a different barrel cable to fit that box.
I have two S95 Meta's, so it's not that the box is faulty, works fine with the one adapter I have left. I'm not sure if the barrel connector could be wrong, or if it really does need a 3A when other S905 boxes don't?
Many thanks
