Ugoos ut3 running on rkm902ii
The latest ugoos firmware runs very fast and well on the rkm. I am thinking of digging farther in it to see what else can be adjusted. I modified one box with fan and I would not try without one. Getting 52-53000 in antutu. Everything else working bluetooth network wifi ect.... Interesting so far.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Tags: None
...yup, compared to RK3368 the RK3328 runs hot as hell. I polished and upgraded the heatsink on one years ago because it just generated too much heat - and that's the only one I've done that to, and it's also the only one I've never cared to overclock
edit: the RK3288 just run too hot, it's not that Ugoos has high clock speeds, they're known to be notoriously slow/conservative with their clock speeds. Even DDR clocks on Ugoos/Nagrace devices are stepped and even underclocked by mo123 - on RK3368 the DDR is clocked 25% lower than all other stock DDR clocks from other devices, despite supposed 'premium' components. Same on RK3288, I don't remember the exact percentage though.
I don't know why they do that, it doesn't make any sense at all on a TV box.
Who knows but ugoos firmware running at 1.8 and without cooling will fry the mk902ii.... I have great heat sink (lappedand 3 inch case fan glued to bottom with ball bearings for feet so works perfect for this box.... my ut3 no issues at all with fan set med range.
Will be happy to see 7 and chrome os hope even Flint on the 3288.... but from what ive seen so far thinking mid july late august before even test versions are out as its a total bag of bugs on items Ive seen so far.
Originally posted by scooter2014 View PostWho knows but ugoos firmware running at 1.8 and without cooling will fry the mk902ii.... I have great heat sink (lappedand 3 inch case fan glued to bottom with ball bearings for feet so works perfect for this box.... my ut3 no issues at all with fan set med range.
never saw a Picture of your UT3 Cooling Work , can u upload one to see ???
nice Day
gefattern
Yup but working on mk90211. Had to install fan going to play with swapping out things when time allows. Last firmware it had no WiFi this one no issues 56000 antutu so good to go with fan modMany devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
There are currently 530 users online. 0 members and 530 guests.
