Hello everyone
.gif)
.gif)
GT1 Android 7.1 is coming to you guys!
Current Version: GT1_701N0_Beta1
Based Version: GT1_701N0_Beta
Applicable plate type: S912 2G 8G/16G/32G QCA9377(wifi+bt) 1000M Ethernet
SD card Upgrade:
https://beelink-my.sharepoint.com/personal/firmwareservice_beelink_onmicrosoft_com/_layouts/15/guestaccess.aspx?folderid=103e8c18a1dc14edfb7d9241 53dc5a7bc&authkey=AYSX2wwe15IUQNrTHMiqMiA
USB Upgrade:
https://beelink-my.sharepoint.com/personal/firmwareservice_beelink_onmicrosoft_com/_layouts/15/guestaccess.aspx?docid=18a4767df43db4697b59e63cd6c 156e4e&authkey=AeD_mCHrKIj3x5dGHe6tM60
Additional Features:
1. Restore the mouse key on the remote
2. Restore the problem of power key that can not awaken dormant state.
3. Open Root permission.
4. Increase Launcher.
5. Support NTFS/CIFS File System.
6. Any other question.
Known Problem:
1. WIFI throughput test: RX is lower than normal under the mode of 2.4G or 5G
2. No focus of the remote on some interfaces in Settings: the remote can not select options on "Do Not Disturb access", "More", "Security", "Accounts", "language & input", "Backup & reset" and "Accessibility" in Settings.
3. Video playing with Miracast APP on Phone can not output voice by connected Bluetooth speaker.
4. Voice set into discretionary choices , SPDIF and HDMI can simultaneously sound.
5. when entering into Settings, loading will be slow sometimes.
If you have any problem, please contact me:
[email protected](Skype)
[email protected](Skype/Facebook)
