Please help to test the video skip problem fix beta firmware on mk908
    Guys:
    This is a beta firmware to test the video skip problem, tronsmart engineer use the newest patches which rockchip release, and pack this beta firmware.
    We need some tester and report back.
    Thanks!!
    download link:
    Looking for developers
    Thank you very much for this new firmware.
    I just try and there is improvement but it is not yet perfect.
    720p mkv is almost perfect but it still stutters with 1080p.
    Again thank you for the work done, it gives us hope.
      Originally posted by geekbuying View Post
      Guys:
      Thanks!!
      download link:
      http://www.mediafire.com/download/vr...est_update.rar
      After upgrading to this firmware my MK908 won't start (no picture/sound on the tv), it works fine if I roll back to the last official release.
      Any ideas what I'm doing wrong?
      Thanks,
      Seb
        No improvement with a SD movie played with MX Player.
        The same with Youtube.
        Crap.
          Guys:
          Thanks!!
          download link:
          The best firmware for me720p movie work very good with mxplayer pro and its better with 1080p movies but not perfect.
          I have better result than the strauzo kernel with strauzo kernel i have stutering in my mk908
          no amelioration in wifi i have very bad connexion with this firmware
            Thanks,
            Seb
            Me too. Not working.
              Any hope for a T428 version, or Tronsmart completely stopped supporting it?
                @fonix232, once the video skip frame problem solved in this rk3188 chip, then all of the models will get update,please don't worry.
                Guys, Thanks for the feedback.
                I hope there will be more feedback, please help to test!!!
                  I have an 5V3A adapter for MK908, works fine in 15/7 rom with enough power to drive without blackout or reboot. Just restored with this rom, first thing bothers me is rapid blackout constanly. Will report more info later.
                    Guys:
                    Thanks!!
                    download link:
                    Any chance to have SDK 2.0 even as a test/beta soon?
                      Please try this T428 kernel (for example in a finless 1.5a rom):
                      I think I might have found the root cause of the video problem
                      Please remember that any problems in video playback from network / internet could also be caused by network related issues. I've only tested the fix on a video file played from the micro-SD card.
                      Want to thank me for my work? Donate to one of the administrators of this forum here or here, thanks!
                        WOW, just check 720p from network with mx player, real good... use last firmware from tronsmart and your kernel. I will continue testing. WOW again... at last something without losing other stuff!
                        T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
                          Could you do the same thing on MK908's firmware ?
                            Someone already did:
                            I'm sure more kernels for the MK908 will follow
                              here´s what I´ve done for the mk908. as usual, use at your own risk! >.>
                              If my work benefits you and you want to help out the cause, feel free to
                              http://www.hoaby.com/android/donate.gif
