Open case with two clips at hdmi side push in gently and pull center out slowly.
remove 2 screws so board is able to be removed.
with board part removed check to see where you can relocate farther away from wifi.
remove the foam pad.
tape into place with electrical tape leaving 1/8 th of the end of the wire after the bullet exposed.
Tape firmly in place so it wont move.
Because short lead think it making some interference from wifi chip.
Once i moved mine wifi strong and no connection issues Bullet type standard good ones so was curious why it was so low.
Mines working fine now.
Hope it helps anyone with same issue.
