Wifi and Ethernet Disconnect on any 3188 I flash!!!
    Hi everyone. These devices are driving me crazy! I have flashed over 100 android tv boxes (including almost any soc chip avaliable) in my life the last 4-5 years! Especially rk3188!
    The last 4-5 days i am getting a very strange problem! I am using same way of firmware flashing as i used many many times, but the problem i am getting is that the last few days, any tv box i flash (q7, minix x7, cs968, kr-42 and more), everything looks normal, boot normal, but on all boxes, ethernet and wifi get randomly disconnected every few seconds or minutes! I mean, the box boots up normally, ethernet connection looks ok on upper right corner of my screnn, everything seems to work ok, but i see the ethernet connection icon dissappearing every few seconds!!!!!
    this happens on any rk3188 i try to flash the last days! i have tried different cables, different usb ports, uninstalled and reinstalled rockchip drivers and many other options i think i have!
    Anyone has any idea???
    Hi dracosc22679 ,
    this sounds very strange , before it worked well with the Devices you flashed ???
    What about Stock Firmware ??? same Problem ??? if you flash .
    Hope you can get it back to life .
    greetings
    gefattern
