V88 Plus
No I haven't it really isn't mine its my brother in law and I'm helping him with it, he bought this thru the Wish app and what's curious is that the order says MXQ Pro Amlogic S905 Smart TV box and at first what I was downloading was actually for Amlogic until I decided to open the box and find out to my surprise it's an MX4N-V02... it's hard to trace this seller all the app shows is the store called LIJIHUA , I recall when it worked it had lollipop 5.1.1
Originally posted by anthony96 View Postgeacmbo,
Pretty sure any v88 firmware should work on that mx4n board assuming you have SSV6051 WiFi chip. Have you tried this one http://download.appinthestore.com.s3...09_Spectek.zip ? Also make sure you use android tool 2.1 select your IMG > erase flash > upgrade.Minix neo x7 custom quickshot V3.1 kitkat with cpu1700 video stock and oc ram 720 kernal
HTC Amaze 4g unofficial cyanogen mod 11 KitKat 4.4.4
ASUS Nexus 7 (original 2012 tegra 3) Cyanogen mod 12 Lollipop 5.0.2
Side note i used rktool 1.7 with the new rk driver package.. and had to take device out of case to use a screw driver to push the flashing button wedged between the button and av port (not the best place for button....)Minix neo x7 custom quickshot V3.1 kitkat with cpu1700 video stock and oc ram 720 kernal
Originally posted by neodoom View Post
we have a winner!!!! thank you for this file my Scishion V88 Plus using 6051p wifi is now running android 6 and netflix audio lip sync is perfect... now i have a working wifi and device is much more usable (garbage with stock firmware android 5) my problems have come to an end but it was fun hunting down this file (were do you find the firmwares i could not with out your post anthony96 your the man....)
Thanks @neoddom, I'll give a shot once again I think this one anthony96 shared a while ago. My problem when flashing some of these firmware run complete others fail during the check and they either fail around 75% ot 97% nevertheless they still boot but oy to the Recovery Mode... all firmware I've tried so far they get stuck on the boot logo screen and after a very long while the screen may or may not turn green. Since the flashing has turned successful in some cases, I've discarded my NAND chip gone bad, what I'm concerned about is the possibility of other chips gone bad that I can't see.... if i'm successful i'll post an update... appreciate you guys pointing me in the right direction at least now I know what to look for... thanks. G.
geacmbo,
I just checked my AliExpress account (don't normally login) and a seller actually replied. Link is super slow as it's hosted in China but here it is https://pan.baidu.com/share/link?sha...&uk=3461034117
Not sure if you had any luck with the one I sent you? I also happened to get another firmware, uploaded it to mega since China servers are terribly slow. Here's the link https://mega.nz/#!wLoQUYAY!wtlys3vWl...bH5G81Sm8aWR8s
Anthony, I've been trying.. LOL I have not been able to download any of those images, using your links I've landed on sites where I've seen tons of images more than any other place I've visited yet I am unable to download any of them, I believe I have to donwload some sort of a cloud application I attempted it and got spammed like crazy ... and to top it off, all sites are in Trad.Chinese so translating them has been also a pain in the butt.... anyways.. my guard is still high and hope to find the right one.. not giving up... I'll check this new one you shared on 7/14... Thanks partner
Originally posted by anthony96 View PostNot sure if you had any luck with the one I sent you? I also happened to get another firmware, uploaded it to mega since China servers are terribly slow. Here's the link https://mega.nz/#!wLoQUYAY!wtlys3vWl...bH5G81Sm8aWR8s
Originally posted by geacmbo View PostAnthony, I've been trying.. LOL I have not been able to download any of those images, using your links I've landed on sites where I've seen tons of images more than any other place I've visited yet I am unable to download any of them, I believe I have to donwload some sort of a cloud application I attempted it and got spammed like crazy ... and to top it off, all sites are in Trad.Chinese so translating them has been also a pain in the butt.... anyways.. my guard is still high and hope to find the right one.. not giving up... I'll check this new one you shared on 7/14... Thanks partner. I'll download it for you and upload it to my mega account.
There are currently 2908 users online. 1 members and 2907 guests.
