HELP! M8S is dead - No Blue light
    Hello All;
    I have M8S Amlogic S812...
    It had a problem
    "Blue light was on. on TV I got just AMLOGIC screen. device wasn't move to android. it was repeating itself on same screen"
    I tried SD boot. but It didn't work.
    I tried USB burning tool,
    reset button + USB + Power.... it connected to PC.
    but all the time I got the Error at %2:
    [Err]--[0x10105002]Romcode/Initialize DDR/Read initialize status/USB Control setup error
    And I had to plug out and do it again for reconnect the device to the PC
    but once;
    I removed all ticks, I just kept "erase Flash" in burning tool.
    and I got completed.
    but nothing has been changed.
    I tried to circuit NAND pins.
    I don't know if I made a mistake but now;
    There is no Blue Light.
    There is no image on TV
    but now, I don't need to click reset button, if I plug USB + Power, it directly connects to PC.
    If I want to use USB Burning tool; again I'm getting the same error.
    but now, I don't need to plug out and in again, its refreshing itself and tries again and again but getting same error in same place.
    NOTE: It is solved by using this firmware:
    https://mega.nz/#!1Fw1Ta5a!0kpwpqjiY...Q-B09FRcGrsAHY
    NOW:
    Wi-Fi is not working.
    I can't make it "ON"...
    A picture of the PCB board with wifi cheap will help here.
