Bricked 905x mxq pro.......everything tried!
    hi all,
    so i flashed the wrong firmware on the above box and literally tried everything , sd card , usb burning etc and normally im pretty good at getting them back but this one...........stubborn little ...
    any ways what i have tried is every firmware for this box , and it keeps getting stuck on this... i have cut a bit form the log
    [18:57:57 065][Global][Inf]--Scan USB host controller complete
    [18:57:57 065][Global][Inf]--Update data center with HubMap
    [18:57:57 065][Global][Inf]--Update hub3 device data
    [18:57:57 065][Global][Inf]--Update HUB3-1
    [18:57:57 065][HUB3-1][Inf]--Update device path
    [18:57:57 066][Global][Inf]--Update HUB3-2 \\?\usb#vid_1b8e&pid_c003#6&2cebe449&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    [18:57:57 066][HUB3-2][Inf]--Update device path
    [18:57:57 066][Global][Inf]--Update HUB3-3
    [18:57:57 066][HUB3-3][Inf]--Update device path
    [18:57:57 066][Global][Inf]--Update HUB3-4
    [18:57:57 066][HUB3-4][Inf]--Update device path
    [18:57:57 066][Global][Inf]--Update HUB3-5
    [18:57:57 066][HUB3-5][Inf]--Update device path
    [18:57:57 066][Global][Inf]--Update HUB3-6
    [18:57:57 066][HUB3-6][Inf]--Update device path
    [18:57:57 312][HUB3-2][Err]--[18:57:57 312][HUB3-2][Inf]--Failure : 2, FailureMax : 3
    [18:57:57 813][HUB3-2][Err]--usb_get_configuration ret=-5 error_msg=sending get cached configuration ioctl failed, win error: The system cannot find the file specified.
    [18:57:57 813][HUB3-2][Inf]--Failure : 3, FailureMax : 3
    [18:57:57 900][HUB3-2][Err]--[0x30405002]UBOOT/Partition boot/Verify patition/USB Control setup error
    [18:57:57 901][HUB3-2][Inf]--Close device handle 0x000002a4
    whats interesting is , it is stuck on usb mode , when opening burner tool dont have to toothpick it , comes up as soon as i just connect the usb lead? which dont look good
    i have disable driver sign enforcement as im on win10, tried another usb lead
    Finally i thought i would flash it via sd, so i make sd card , hold the toothpick in , andriod man comes up get a quarter through and the red cross appears??
    literally i am out of options and advice would be brilliant but i think i have done everything
    i havent shorted pins yet as i dont need to as usb burning dont need it in my case
    please find attached the board pictures
    anyone ??
