MXQ PRO 4K - S905x V3 FIRMWARE NEEDED P212
    Hi Everyone,
    I have tried everything in terms of loading firmware, somehow the only firmware that USB BURNING TOOL seems to flash is the Nexbox A95x firmware. Im not sure if im looking for the right or wrong firmware but everything besides the A95x has been failing with "usb setup error"
    Thanks in advance
    Hi Everyone, have the same problem as above, any one with firmware for this would be a lifesaver.
      try this stock ithink i found http://freaktab.com/forum/tv-player-...349#post647349 https://mega.nz/#F!GJtTBQZL!5gBpvh-hbkQW7gcJfyKDyw
      and the main OP for custom image
        Thanks, will try this when i get home and let you know about the outcome.
        UPDATE:
        I Have just tried this now, i get a usb error code when using usb flashing tool. ahhh... this is becoming so frustrating now, starting to give up.
        UPDATE 22/05/17:
        So i took the https://mega.nz/#F!GJtTBQZL!5gBpvh-hbkQW7gcJfyKDyw and replaced all the boot.usb(from the nexbox a95x rom) files using Customization tool and it flashed and booted up, seems good. Rom is slow though and WIFI doesn't seem to work. But atleast the box is alive. Thanks @bothered
          UPDATE:
          UPDATE 22/05/17:
          You could please tell me what files you replaced exactly, since I have managed to run my MXQ PRo 4k, but it does not have wifi, and I found one that says it is complete with the wifi solution and I want to try to recover my TV BOX, well run the wifi again, thank you. I hope you understand me, because I do not speak much English XD
