Brand: MECOOL Model: KI PRO Type: TV Box System: Android 6.0 Processor: Amlogic S905D CPU: Cortex A53 Core: Quad Core GPU: Mali-450 RAM: 2G RAM RAM Type: DDR4 ROM: 16G ROM Max. Extended Capacity: 32G Maximum External Hard Drives Capacity: 32GB TV Box Features: 5G WiFi |
Decoder Format: H.265 Video format: ASF,AVI,DAT,FLV,ISO,MKV,MPEG,MPG,RM,RMVB,TS,VOB,WM V Audio format: AAC,APE,DDP,FLAC,HD,MP3,OGG,TrueHD,WAV,WMA Photo Format: BMP,JPEG,PNG,TIFF Support 5.1 Surround Sound Output: Yes |
5G WiFi: Yes Bluetooth: Bluetooth 4.1 Power Supply: Charge Adapter Interface: DC 5V,DC Power Port,HDTV In,LAN,Optical,TF card,USB2.0 Language: Multi-language Power Consumption: 8W RJ45 Port Speed: 1000M |
System Bit: 64Bit |
Power Type: External Power Adapter Mode |
Product weight: 0.1630 kg Package weight: 0.5920 kg Product size (L x W x H): 13.00 x 12.00 x 3.20 cm / 5.12 x 4.72 x 1.26 inches Package size (L x W x H): 16.25 x 14.50 x 8.55 cm / 6.4 x 5.71 x 3.37 inches |
Package Contents: 1 x MECOOL KI PRO TV Box, 1 x Power Adapter, 1 x HDMI Cable, 1 x English User Manual |
MECOOL KI PRO TV Box 905D 2/16GB Dual WiFi, DVB-T2 DVB-S2 DVB-C TV Gig Lan. BT4
GearbestLast edited by trebor; 04 July 2017, 05:17.Tags: None
Lets have a bit of a look at the UI and some performance test and information
This is not a powerhouse unit and more suited to TV Broadcast etc.
Standard MECOOL UI and much the same as other K TV/DTV products
Running Android 7 option to enable lower taskbar and at this stage no ROOT
Tv Centre is a version of Kodi used by Mecool and do as you please.
DTV app is the for Tuning, Recording, TV and other modes that are available with using this Unit.
Runs a little warm.
On the inside a bit of a look at Hardware and what is going on
In the Mecool K1 you will also find a useful software based user manual, reading or Youtube display handy for New users in getting the most of of this TV BO
Tuning is same as most of the MECOOL K series TV boxes
Ran up the DTV app select Auto scan Hmm nothing...Ok help if we plug the TV antenna in first
And Second need to set the Media Player up to Australia found in DTV Preference
Scanned and all channels found easy.
100% Sig and Quality, using Log periodic type antenna about 30k from the TV towers (bit of wet string would prolly do)
Picture Quality looks ok
Time between channel change 2~3 second failry quick
EPG looks ok easy to read, other functions to set up PVR Time Record, Channel Sort, Favorites, Parental Control
Easy as.
I find the Remote is Designed more for the TV/Sat function of the box than Normal Android.
I normally use the k400 logitech with android it not a problem here, other may find it a problem.
First thing get greeted with when running the DTV App
Menu to Select Country/Region, select DVT Preference
ONce set back to Installation and scan
Easy
EPG from Remote
All features selected are overlayed a top of the TV Image,
Was not able to snap TV Images only overlays at this stage.
All funtions are access from remote.
ON Screen Display (dark room picture lights out)
Edit Channel List
PVR Settings
PVR Storage Device
Favorite Channel to be added
Channel info and Sub titles
And a little music if the FTA gets to much
There is a little about the TV function easy as really if you have a spare PC monitor
and need a FTA this is an option to consider.
Not to forget a bit of a look on the the inside the K1 Pro DTV Unit
For a 2/16 with Tuner around 80$ not a power house machine but does the job
Gearbest
An excellent Custom Rom for this Unit can be found:
http://freaktab.com/forum/tv-player-...-1-1-scv1-beta
Faster, smoother not as Hot so a Cool Mecool
New Software can be found
KI_PRO_AVL6862-ota-20170725.014430.V0619.zip
https://mega.nz/#F!0uowxDjA!tNknA9Iq38iReadwZwpvRg
Tested for a few hours.
HD Sync was Good, as it tended to give the most trouble here
I did see some screen tearing when OSK would be used.
Also these extra apps running for what ever reason. ?
There are currently 1447 users online. 1 members and 1446 guests.
