A95X R2 TV Box 1/8GB RK3328 2.4GHZ WiFI Fast Lan.
How can I flash the firmware? I am searching info without luck. Thanks!
edited: Founded Rockchip Create Upgrade Disk Tool v1.4... Can I use it to flash the firmware?Last edited by Titobustillo; 30 June 2017, 16:45.
I tried Rockchip Create Upgrade Disk Tool v1.4 method but the box just could not detect my micro sd at recovery mode. I give up after many trial.
my method is using rkbatch tool 1.8 with driver assistant 4.4 on my windows 10 32bit. Tricky part is installing driver on windows. I use a (male to male) usb data cable to connect the box to my laptop usb port before I install the drver (run under admin). It will pop up a dialog box asking whether u want to continue with installation. if u never get this dialog box , driver is not installed properly. For your info, I use the usb port beside the blue port.
Another tricky part is to let rkbatch tool detect your box. 1)unplug everything except hdmi cable connected to tv. 2)plug one end of usb cable to laptop. 3) use a toothpick and insert to AV port of the box. You will feel the pressing of a button. 4) while pressing the button with the toothpick, plug the other end of the usb cable to the box. The rkbatch tool GUI menu will show that the box is connected at the bottom left (grey square turn green).
After that is easy, load firmware and wait until complete. Then click restore untill the box is rebooted by itself. be patient do not touch anything during the process. Just want to share my rom burning experience as a tvbox newbie. By the way, I am not an expert in this field. Hope you succeed in burning quest!
There are currently 2448 users online. 0 members and 2448 guests.
