A95X A1 905x, 1/8GB, 2.4Ghz wifi, Fast lan
    Specification
    Model: A95X A1
    Type: TV Box
    System: Android 6.0
    Processor: S905X
    CPU: Cortex A53
    Core: 2.0GHz,Quad Core
    GPU: Mali-450 MP
    RAM: 1G
    RAM Type: DDR3
    ROM: 8G
    Decoder Format: "HD MPEG1/2/4,H.264,H.265,HD AVC/VC-1,RealVideo8/9/10,RM/RMVB,Xvid/DivX3/4/5/6
    Video format: 4K x 2K,ASF,AVI,DAT,FLV,ISO,MKV,MOV,MPEG,RM,RMVB,TS,WMV
    Audio format: AAC,AC3,APE,DDP,DTS,FLAC,HD,OGG,TrueHD,WAV,WMA
    Photo Format: BMP,GIF,JPEG,PNG,TIFF
    WIFI: 802.11b/g/n
    Power Supply: Charge Adapter
    Interface: SPDIF,TF card,USB2.0
    Antenna: No
    Camera: Without
    Language: Multi-language
    HDMI Version: 2.0
    External Subtitle Supported: Yes
    Power Comsumption: 5V 2A
    RJ45 Port Speed: 100M
    System Bit: 64Bit
    Power Type: External Power Adapter Mode
    Product weight: 0.1200 kg
    Package weight: 0.3900 kg
    Product size (L x W x H): 9.30 x 9.30 x 1.50 cm / 3.66 x 3.66 x 0.59 inches
    Package size (L x W x H): 18.50 x 12.50 x 4.80 cm / 7.28 x 4.92 x 1.89 inches
    Package Contents: 1 x A95X A1 Android TV Box, 1 x Power Adapter (5V 2A ), 1x Remote Control, 1 x English User Manual, 1 x HDMI Cable
    Gearbest
    Hi, is there any possibility to root this device? I can´t find any further details about this box. Is the firmware for Nexbox A95X compatible for this device? Can I find any link, which deals with A95X A1. Can I use instructions and tools for Nexbox A95X?. The only mention concerning firmware (apps) I found in costumer review on Gearbest "You can't get better box for money. I run LibreElec/KODI from SD card ,and it's faster than my RPi3 with same software. It works really well as my media hub / streamer. On Android side it's bit sluggish (1gb ram) ,but still has more than acceptable performance for the money. As linux based LibreElec box it's unbeatable! More expensive RPi can't handle UHD , but this little wonder can. And big bonus for Android being rooted". Thank you
      Nickcarter, does wifi work on your libreelec instalation?
      I ordered this box and installed libreelec LibreELEC-S905.arm-8.2-8.1.2.img and wifi is not working. It must use other wifi chip since the same firmware works flawlessly on the nexbox A95x.
        Hi Madds, I´m still waiting for my box, so I can´t answer your question at this moment, I will let you know.
          Do you have install libreelec in this device?
            Hi Kinbico (and Madds), I´m sorry, the seller of my box was a cheater and than I decided that I will buy somehing, which is more supported. I wish you all the best with this receiver.
              I ordered one from gb, is there on the www original firmware img to download, when it comes to my hands i planned to put libreelec to internal memory, but i need backup if something goes wrong?
              Want to buy me a BEEEEER?
                Me too, I find the orininal img for burning tool and I 'll try to install LE in internal. We'll talk about it.
                  where did you find it? - link please..
                  from comments i read about this box and Le, wifi will not work because wifi chilp is not supported cause there is no source for it.
                    I found it in the comments on banggood
                      nice box for 26 usd, libreelec works very well on internal memory.
                        this firmware saved my box from a red light soft-brick but it only uses 1 core in Android
                        the other 3 cores show as stopped and are never used, making the box slow and hot
                        i need another stock firmware for this box that works with usb burner
                        can anyone help me?
                          Did you try any of those? i'm still on LE
                            https://mega.nz/#F!19ggjC4S!GXV3TEWcMDfLi6bNsQKAZw
                            yes tried those
                            nexbox firmware will not flash, they fail at 2%. this is not a nexbox, it's a a95x a1.
                            they're both made by same company cyx
                            also tried building a frankenstein using stock and nexbox images
                            didn't work as well
                            this is mine: http://www.cyxtech.com/T02/cn/product/a95x_a1.html
                            the only 2 firmwares i was able to flash with usb burn is the one i posted
                            and some generic android tv rom, which ran way too slow for daily usage
                            no other stock farmers can be found anywhere
                              @howardo , try to install LE on internall, Its the best choice for this device. I´m trying to dump a clean Android firmware (I have 3 units of them), but I think it hard to do because I can´t reboot in TWRP
                              Could you link me the generic android tv rom?
