H96Pro+ True x8 cores 1512 Mhz GPU 793 Mhz Android 7.1 Alpha (coming soon)
Originally posted by mixir View Post
If you wish, I could PM you a link to HLS stream that play jerky on ALL Androis 6.0.1 for S912 (with HW acc). Recently I flash GT1 Android 7.1 on my Vontar Z5, and that stream play smooth with HW acceleration! But, unfortunatly I could not get work IR remote with box (I edit remote.conf but nothing happen, may be I should edit another file?), and also wifi not work ... So I rolled back to android 6 with jerky hw((
And yes the easy way of remote.conf change its over in 7!
Originally posted by mrdigit420 View Postsuperceleron does this mean you will updating your rom for Alfawise s92/Beelink Gt1 as well ? It's sad that your device broke and you moved on to other devices but we still look forward
Originally posted by gale View PostI tried 7.1 to H96pro+. CPU temperature climbed to 90c.
So you may have lucky and got a "good" one and unlucky and got a "bad" one... its a lottery on this boxes.
Originally posted by gale View PostOnly GT1 has good cooling. I think the problem is somewhere with 7.1. The same problem is with Khadas vim s905x. When working on a 7.1 tv box is more heated.
There are currently 2192 users online. 1 members and 2191 guests.
