Android Box for Moonlight (stream)
    Hello,
    can anyone recommend a cheap Android-Box for Moonlight (stream). I have a nexus 7 and the performance is amazing (21-25ms) but with my qBox (s905) the performance is laggy (80-100ms). I know that device like Nvidia-shild is perfect but it's to expensive.
    Im searching a cheaper Box, between 30-60€.
    Thank you
    have you have found your box yet?
    little to no information about this on the web. seems not many use this feature.
    only youtube reviewer that tests moonlight doesn't share any numbers and only says that his experience is good in every review
    can't believe that, eighter he has no sense for LAG or he's lying. they can't all be good.
      No sorry ☹️
        Sent you a PM
