Or is it possible to expand the internal memory with an SD card? I found a tutorial for android TV, but can this also be achieved for lets say android marshmallow? I want to be able to install apps and games on the SD card, not only store data on it.
Upgrading an android box?
Maybe a dumb question but can you upgrade an android box as in desoldering and replacing RAM or ROM? I'd like to stick with a S905X box because of LibreELEC, but also need more then 16GB of internal memory. Since there are no boxes with this chipset and 32GB ROM, hence my question
Or is it possible to expand the internal memory with an SD card? I found a tutorial for android TV, but can this also be achieved for lets say android marshmallow? I want to be able to install apps and games on the SD card, not only store data on it.Tags: None
There are currently 2691 users online. 6 members and 2685 guests.
