Can someone please post a link to a .zip of LibreElec 8 for S812? I have a Matricom G-box Q2 so I believe I need the MS version. I have been searching everywhere for a .zip to flash with zero luck. Thanks.
LibreElec 8?
hmm...
libreelec has a installation app..that creat's a bootable sdcard
So, you can first test libreelec without losing android
note:
if you choose to use the zip file option and you choose the wrong one...you might brink your device
files are here..
Download GApps, Roms, Kernels, Themes, Firmware, and more. Free file hosting for all Android developers.
info here
LE 9.0 Stable is out and i can no longer build so many images as before due to lag of time,the amount of time the new build system needs to finish and the fact that i already ruined 2 hdd in the process. So, I will release LE9.x images for only for…
cheers
Balbles over on the Libreelec forums has a thread going with builds of 7 and 8 that live boot from SD:
There are currently 2136 users online. 4 members and 2132 guests.
