Thanks in advance
Unbricked t95z plus 3gb 32gb
Hi i have a t95z plus 3gb 32gb. I want to flash the fw, because it’s verry unstable on my box. Now the clock in the front is completely off. The led ont the top is ok. The optical port working (red light). My wifi chipset is 8330. I try update with sd card and succes but few hour later the box crash. I Try to flash with usb burning tool (many version) with no succes, i use this topic https://www.entertainmentbox.com/how...-burning-tool/. I try original rom and superceleron v1 final rom with no succes. Always crash at 4% with this error code [Err]--[0x10303004]Romcode/Switch status/Identify/Error result. What can I do for that. I try many thing and always crash.
Thanks in advanceTags: None
Hi i try everything and nothing...try different version of usb burning tool with no success, connect and disconnect power from the box, try different usb port on my pc, reset no reset. Different img, different settings in usb burning tool, start usb burning tool flashing img before connect my box....i search on this forum and i try practically everything, youtube......nothing always the same problem stop at 4% ]--[0x10303004]Romcode/Switch status/Identify/Error result....
any help must be appreciated
excuse my English i'm french canadian ;-)
There are currently 1000 users online. 0 members and 1000 guests.
