M6 and screen sensitivity
Just to know if someone can help me, or knows a solution to my problem. When charging my M6 it almost gets unusable due to the seemingly 1000-fold increased screen sensitivity. In the M6 1.3 rom section someone told me this happened when charging your M6, but how to solve this, I don't know. Anyone has a clue as how to solve this, as its really annoyingTags: None
Originally posted by Piet View PostJust to know if someone can help me, or knows a solution to my problem. When charging my M6 it almost gets unusable due to the seemingly 1000-fold increased screen sensitivity. In the M6 1.3 rom section someone told me this happened when charging your M6, but how to solve this, I don't know. Anyone has a clue as how to solve this, as its really annoying
I have the same tablet with the 1.4 Rom. I don't have your problem. Maybe you can upgrade and try again.
JoostLast edited by Joost; 29 July 2013, 07:28.
This problem happens on several 3188 tablets...and it isn't the ROM.
It is actually a variation in the quality of your external charger. People have solved the problem by replacing the charger adapter. This is why some people experience the problem and other's don't. I have the that problem with my Cube U30GT2 tablet, but with none of my other devices...I just haven't gotten a new charger yet for it.
Be VERY careful about finding a replacement, though. The battery packs come with circuitry that is designed to protect the battery from overcharging or from full discharge which will kill the battery. If the specs are off just a little bit, it will fry this circuit and your tablet won't charge or power on.
So, you must obtain a charger that is specifically designed for your device...otherwise you risk permanently bricking it.Randy
There are currently 1486 users online. 0 members and 1486 guests.
