VORKE V1 Plus Intel Apollo Lake J3455 4G RAM 64GB SSD AC WIFI Gig LAN Bt4.0 HDMI & VGA USB3.0 - Black
    Click image for larger version  Name:	20170517017183718t675z3 (1).jpg Views:	2 Size:	12.8 KB ID:	647202
    J3455 , a quad-core processor, operates between 1.5and 2.3 GHz. Under the hood, it packs 2 MB of L2 cache, TDP of 10W and a Intel HD Graphics 500 GPU.
    DDR3 4GB RAM, 64GB SSD, Both Extendable
    VORKE V1 Plus brags a 4GB DDR3 RAM and 64GB of SSD storage, advantageous in performance, security and reliability. Ascribing to the eMMC memory, it delivers a richer end-user experience.
    SDD unlimited, HDD 1TB.
    Gigabit LAN
    Gigabit LAN provides a data rate of 1 billion bits per second.
    Applications
    Office Work: Office, skype, yahoo, outlook and all other office requirement support and runs perfectly.
    Design Work: Photoshop, CoreIDRAW, Dreamweaver, IIIustrator, Flash, Indesign and others.
    Game Playing: Support most of the online games and PC games, like Warcraft, Counter-Strike (CS), support 3D games.
    Entertainment: Support 4k video play, XBMC and others.
    Click image for larger version  Name:	2017051701718411wpls3a.jpg Views:	1 Size:	9.3 KB ID:	647204
    eneral Brand: Vorke
    Model: V1 Plus
    Quantity: 1 Piece
    Color: Black
    Hardware & OS Operating System: Windows10 home 64-bit, Supports WIN8.1/ubuntu15.10&16.04 Chrome OS
    CPU: Intel® Apollo Lake J3455(1.5-2.3Ghz)
    GPU: Intel® HD Graphics 500
    RAM: LPDDR3 4GB (1600MHz)
    ROM: 64GB mSATA SSD(Endless extension for SSD, 1TB extension for HDD, Support 2.5" SATA3 SSD)
    Sound Codec Chip: Realtek ALC269
    Communication Wifi Connectivity: Intel® Dual Band Wireless-AC 3165,802.11ac,2.4G/5G
    Ethernet: Gigabit LAN
    Bluetooth: 4.2
    Card Reader: Micro SD card slot(Realtek RTS5170)
    Media Video Supported: 3GP,AVI,H.264,MP4
    Audio Supported: AAC,ACC,MP3,OGG,WAV
    Picture Supported: BMP,GIF,JPEG,JPG,PNG
    Office Format: Excel,PPT,Word
    E-book Format: PDF,TXT
    Interface HDMI Port: Standard HDMI Male 2.0a,Support 4k@60Hz
    Wake On LAN: Yes
    Other Interfaces
    USB2.0 x 2
    USB3.0 x 2
    Headphone out&Mic-in x 1
    VGA x 1
    LAN 10M/100M/1000M x 1
    TYPEA HDMI x 1
    Power Button x 1
    DC-IN x 1
    Power Power: 12V//3A
    Skype: Supported
    Youtube: Supported
    Speaker: Supported
    MIC: Supported
    Dimensions&Weight Dimensions: 153.4*153.4*38mm/ 6.039*6.039*1.496inches
    Weight: 390g/ 13.75oz
    Package Contents 1 x MINI PC
    1 x Power adapter (A right AC Adapter will be sent as your shipping country)
    1 x Charging cable
    1 x User manual
    Click image for larger version  Name:	2.jpg Views:	1 Size:	77.3 KB ID:	647467
    Click image for larger version  Name:	1.jpg Views:	1 Size:	148.3 KB ID:	647468
    Geekbuying
    Click image for larger versionName:	v12.jpgViews:	1Size:	104.0 KBID:	647817
    Geekbuying
      10$ Bucks of with this
      Coupon: VORKENEW
      $189.99.
      Geekbuying
        Today we got to have a look at the New Vorke V1 Plus, with its Improved CPU, rest is must the same as previous model as far as build goes.
        The top cover cover of the Vorke V1 Plus is a Matt finish previous V1 was a Black gloss, the rest looks good as previous model.
        Bluetooth: 4.2
        Whats in the Box and an AU Power Cable Nice to see
        Click image for larger versionName:	3.jpgViews:	1Size:	59.4 KBID:	649568
        Ports and more ports and Vents Good to see.
        Base Plate off to Install SSD or HDD
        Look Inside all the good bits, can update Msata to a larger size, just see the 2 WiFi Tape Antenna top left and right Click image for larger version  Name:	11.jpg Views:	1 Size:	226.0 KB ID:	649566
        Click image for larger version  Name:	10.jpg Views:	1 Size:	220.3 KB ID:	649567
        Not doing a full tear down this one much the same as previous Vorke VI excluding CPU and Ram that cannot be updated in this unit 4GB is it.
        Thanks Geekbuying and DHL for the usual Quick turn around..
        Now for the set up....More to come.
          After putting Vorke V1 plus back together power up and see what we have
          After a Minute we get greeted with the first of the Windows setup screens
          Click image for larger version  Name:	a.jpg Views:	1 Size:	79.1 KB ID:	649576
          Basic input and away it goes with a restart.
          Then we get to this screen
          Click image for larger version  Name:	win-10-customize-settings-100600418-large.idge.jpg Views:	1 Size:	59.6 KB ID:	649578
          Customise settings then you can adjust what you like
          We want to know all about you and tell the world settings.
          About three of these screens I select no for the lot...tell em nothing, takem no-ware
          Click image for larger version  Name:	Windows10Privacy.png Views:	1 Size:	12.7 KB ID:	649577
          So after a bit more loading and carry on and other restart, may ask also to set up Internet skip that for now and do it later.
          We finally get to Windows, a few minutes really as the Vorke V1 Plus has bee set up properly should be easy to get windows up and running and yes a full windows Home Version.
          Version 1511 at the time of boot so a little updating to do.
          Click image for larger version  Name:	winver.jpg Views:	1 Size:	27.1 KB ID:	649579
          Click image for larger version  Name:	2 (2).jpg Views:	1 Size:	69.6 KB ID:	649580
          Bit of customising setting date time other bits, location, install a few programs,
          Click image for larger version  Name:	3 (2).jpg Views:	1 Size:	74.8 KB ID:	649581
          Then onto the first update.....Just to get windows in the right frame of mind, update Defender and other software...this part took about 30 minutes and all went smooth.
          Click image for larger version  Name:	5 (2).jpg Views:	1 Size:	32.4 KB ID:	649583
          All updated to a point.
          Then we go for the second update to get the Creators Update
          Download a small app called Update Assistant it goes away and does it's thing in the background and we
          hopefully end up with windows to the latest and greatest.
          Click image for larger version  Name:	4 (2).jpg Views:	1 Size:	35.2 KB ID:	649582
          20 or so minutes later all is downloaded and yep another series of restarts...should get us to the latest and greatest
          So far so good, Vorke V1 plus moving along well no major problems at all, not to much noise form fan and unit is not overly warm.
          So that is pretty much the start up nice and easy no problems fully activated, and should be a happy little Vorke V1 plus soon.
          Geekbuying
          Bench test and info to come next
            Vorke V1 plus is going well no problems, Creators update in and all smooth,
            fan ok no excess noise when pushed keeps it cool very well, and no problems with running just 4GB ram and 64GB mSata.
            After doing Update i was able to recover 20GB of old windows/install files currently using 16gb of mSata.
            Great Unit for Office or Home, Media server, Linux Box, Not a power house box but can do most.
            Quick Look at Major system Hardware and what's going on inside.
            Antutu Benchmak
            Diskmark Speeds
            Ethernet connection good
            Stress test moved a little and that was it...Cool down also quick
            Passmark scores good for what this box is
              Available also as an option and not included pity
              Vesa mount for easy mount to TV.
                Bit of Look around the Cmos and what it has...one
                So much to see and do, one could easily make a mess of it.
                Click image for larger version  Name:	nix.jpg Views:	1 Size:	98.4 KB ID:	649764
                And A bit of a capture while live streaming HD Video
                Very smooth video local bit jerky with the capture, but you get the idea.
                  Today a bit of a fiddle with Linux on the V1 PLUS
                  Using Rufus to create bootable USB stick.....
                  Into cmos and selected Boot USB, Done
                  After a few seconds Install or run Menu I ran form USB stick....easy
                  All working easy and well Sound, Ethernet, WiFi and BT pretty easy not get Mint running on the Vorke V1 PLUS
                  Geekbuying
                    Looks like a great PC (tower) alternative and it's a lot smaller.
                      This box states that it has HDMI 2.0, which should mean 4k@60hz.
                      Can you confirm that this is the case?
                        Yes
                          Thanks.
                          Finally good to see an Intel box with pretty much all the bases covered.
                            What do the sound capabilities say about HD audio support?
                            It seems as though there are different board revisions for the J3455, one of which doesn't seem to support DTS HD, TrueHD etc, just the usual Dolby/DTS.
                              You have answered your own question I feel.
                              If I find the time I may look further...
