Sent from my T428 using Tapatalk 4 Beta
converting custom roms img to update.img
Hi guys. is there a way to use the custom rom img files as the update.img file that can be flashed from the sd card. like the stock rom i mean.
Sent from my T428 using Tapatalk 4 BetaFIRMWARE & HARDWARE COMPATIBILITY LIST FOR ANDROID TV STICKS
https://docs.google.com/spreadsheet/pub?key=0ApGXribKk_8gdEc3YnlmOHlfRlRQVUxFbkJ3Zzg3U EE&output=html
My Plexi MK802IV mod
http://www.freaktab.com/showthread.p...xi-MK802IV-modTags: None
Re: converting custom roms img to update.img
Originally posted by neoal View PostHi guys. is there a way to use the custom rom img files as the update.img file that can be flashed from the sd card. like the stock rom i mean.
Originally posted by leolas View PostI think that there is a tool for linux to do that, sorry but I am from a mobile device and I cant check it, but there is rkunpack tool that i use to extract the img files from the update.img and there must be an option or maybe other tool to pack them again. Lewy I think that used that tool in his roms some times.
leolas
Nop, that will noy work cause stock update.img have a script inside, once you unpack update.img you got the img files, a kernel raw img, a script , parameter file, bootloader, and I can't remember if some more files. So to use this way to upgrade your stick, you must unpack a stock rom, substitute the stocks img files for the new custom img files and repack
thats what im trying to do. to repack the components of a stock rom into an update.img so that i can flash it from the sd. but i hope it doesnt break my t428. cause from this moment im only guessing.
I never try it too, to be sure better ask lewy, I think he repack in this way some of his customs.
Originally posted by leolas View PostI never try it too, to be sure better ask lewy, I think he repack in this way some of his customs.
leolas
its number 4 you must have.
just rename the stock.img to wendal and place it in the extracted folder.
and then click on Runme batch tool.
and then follow the instructions.if you love my work please buy a coffee
<form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
</form>
thx snakerom but i need to repack the rom not to unpack it. i want to repack a custom rom, any custom rom to a single file like the update.img that tronsmart provides
When you unpack the stockrom then you can repack it again with this tool
Verstuurd van mijn GT-S5660 met Tapatalkif you love my work please buy a coffee
</form>
thats great but what about packing the custom roms, will it work with them
Originally posted by snakekiller View PostWhen you unpack the stockrom then you can repack it again with this tool
I think sow just replace the .img files in the temp folder and repack it again
</form>
thx ill try it with one of the roms that i find here at freaktab.com cause i want to use it for the xbmc app more
Originally posted by snakekiller View PostI think sow just replace the .img files in the temp folder and repack it again
Verstuurd van mijn GT-S5660 met TapatalkFIRMWARE & HARDWARE COMPATIBILITY LIST FOR ANDROID TV STICKS
Did you replace the parameter also ?
Because the custom system.img is maybe larger then the stockrom
</form>
There are currently 4573 users online. 0 members and 4573 guests.
