Android box with gigabit?
Thanks for the link. I like the esata, but as you said the processor is a little lacking. From what I've seen ~1.2ghz arm can saturate a 100mbit connection, I'm thinking the processor will be the bottleneck on the cuBox. I think cubietruck is the closest thing going to what I want. http://cubieboard.org/2013/06/22/the...ck-discussion/ Wish it had the A31. If the sata supports port multiplication then I will be set.
There are currently 1731 users online. 0 members and 1731 guests.
