H96 pro+ 3gb 32gb
    H96 pro+ 3gb 32gb
    good morning guys
    i having some problem with this box this internet connection both hardwire and wireless keep going in and out
    has anyone had this problem before and any fix for this plz help me out
    thanks to all in advance.
    yes,me too,
    i just try to flash firmware for wifi only
      Try this Firmware Android 7.1 Version: https://mega.nz/#F!d1tHVZgA!Qc0mAom7FBHT9HDv3rGtGQ
      Sent from my Redmi Pro using Tapatalk
        This firmware if does not work then box is screwed right.
        Sent from my SM-G920W8 using Tapatalk
          No show some photos of the board inside. Then we can point yoy in right direction
            hi guys i'm running 6.0 is ok to flash it with the 7.0 ?
              here is my pic
                Hi guys, I have a similar problem, I installed SuperSU from play store and it installed the binaries and requested a reboot and the box is stuck at mbox logo, I tried factory data reset with no success and tried to download several of the ROM available on line and they all return the same errors when I try to flash the by usb stick as an external update.
                the error is
                E: footer is wrong
                E: signature verification failed
                E: error: 21
                Any help is appreciated
                  any help on my problems guys
                    Check if the issues are related with the modem router... try to put a static ip and dns on the tv-box, and test if its working again.
                      the error is
                      E: footer is wrong
                      E: error: 21
                      Try to download from xda the latest flashable (with recovery) supersu.zip (2.82), the issues of supersu comes installing the 2.80 versión.
                      Check if your tv-box have Android 6.01.
                      Find on freaktab or another fórum the twrp 3.02 mod recovery (from beelink gt1) that is compatible with h96 pro+, put it (.img) and the supersu.zip in a sdcard (max 16gb/fat 32), and try to install the super su zip with the twrp recovery.
                      You can see tutorial, and download files on this blog:
                      H96 PRO/PRO+ Android TV Box Amlogic S912 Caratteristiche Tecniche CPU = Amlogic S912 octa core ARM Cortex A53 ARMV8L ([email protected] + [email protected]) rev.4 GPU = ARM
                        plumber ,
                        Nice find on the Link http://xnetfox.altervista.org/h96-pro/
                        Viper4Android and Dolby Atmos mods are very tempting....
                        Reap
                          Originally posted by ReaperMan View Post
                          plumber ,
                          Reap
                          atmos is working on stock 6.01 without recovery (using flashfire)
