New firmware to improve the problem of " google play stopped work ”
    Hi dear , here is the link for GT1312 MO ,which can solve the problem of google play , looking forward your feedback , thank you I
    Current edition : GT1_113M0
    Based on :GT1_111M0
    Users : beelink FIt forFS912 2G 8G/16G/32G QCA9377(wifi+bt) 1000M Ethernet
    USB update zip:https://beelink-my.sharepoint.com/pe...qm3welRYpHhuJ8
    SD card update zipFhttps://beelink-my.sharepoint.com/pe...0R4s324oPuIzNk
    InprovementF 1.Improve the problem of "google play stopped work"
    Please don't hesitate to contact me if you have any question : [email protected] . QQ:918976762 .
    this firmware 113MO can I instal to beelink gt1_A912 AP6255 If cant please give me link for this box with firmware 113MO,Thanks
    Now my firmware is 110MO and i always check update says"your system up to date"
    Why?I buy this box because is have OTA.Why OTA not working not see firmware 111MO AND 113MO.
      Based on :GT1_111M0
      Shame. What about A912? Where is OTA?
      I've made an app to resolve this problem because you cannot solve it for months.
      Hi! I made an app to keep the play up-to-date. The main cause is the bug in official roms (google play cannot be refreshed and show a dialog
        Thanks smrtprjcts
          I don't have a Beelink box. But what about this update method for Google Play Store: https://www.cnet.com/how-to/force-th...te-on-android/
          Doesn't that manual update method work on Beelink?
            Not working due to permission problem.
            And my app can download newer version than this manual method (more version are available at the same time)
              i still can't update google play store i tried smrtprjcts app google play store is replaced but it's not installed at all i tired to replace manually as well the same problem anyone can help ?
                Why do you want to install after the app is already replaced to the latest one???
                  because there is no google play store at all after replacing i changed permission and everything
                    There's a new version with revert possibility. Try it
