Bqeel M9C Max Review
Originally posted by gaizka View Post
Thank you. Any tips on create the USB male to male cable?
The USB M-to-M cable is a plain, pin to pin, 1-1, 2-2, 3-3, 4-4.
Hope it helps.
Originally posted by RISCy Dude View Post
Hello, I don't have this box. However, the USB Male-to-Male cable I use for my RK and AML boxes is as follows. I have made these and they work fine, but is a good idea not to make it too long.
Hope it helps.
Also I assume that by 1-1,2-2,3-3,4-4 you mean pairing the same colors, right?
Thanks for the help!
I am not sure where I heard about avoiding the use of longer cables for flashing, but it sticks in my mind. The M-to-M cable supplied with my Ugoos UT3 is about 12.75"(~32.4cm). While that may have been done for economy, it is not the sole reason I believe longer cables should be avoided. I would try to keep it under a couple feet, but I made one that was about a meter and it worked fine.
By 1-1, 2-2, etc, I mean pin 1 at one end of the cable should be connected to pin 1 at the other end of the cable, pin 2 should be connected to pin 2, etc.. Sometimes known as straight-through wiring.
Note: As far as pairing colors, not all cables or USB device cables adhere to the accepted color convention. When making a cable, it is a very good idea, and highly recommended, to check the cable with a multi-meter prior to using.
Freaktab user ontherocks posted this diagram.
More can be found elsewhere, some examples.....
Youtube video. Nicer to go cable to connector like he does, but I have made some "dirty" cables by just twisting the appropriate wires together, solder and heatshrink or tape.
Freaktab user matafact posted a DIY here.
Hope you are successful, let me know if questions.
hello everybody, my M9Cmax (2/16 gb) is stucked in red led, no signal, no starting logo at all, no remote response, to solve this problem I've tried to flash this rom using usbburning tool but after I connect the device to my pc the loading starts but suddenly ends at 6% giving an error when starting to flash the internal memory; where I'm wrong?, could be a wrong img or a hardware failure? I've tried different versions of usbburning tool, with and without DC connected, changing the temperature limit range, but nothing to do
suggestions?
What roms have you tried.could be a wrong img.
Did you try some custom roms https://forum.freaktab.com/forum/tv-...-roms-tools-bx
Lots of custom rom there
Also how long is the usb lead Some long leads give an error
Another thing is not to touch the box while flashing as a slight movement can make it disconnect and give you the error.Please consider making a Donation to freakTab
ok, I've tried several roms, starting from the one I found at the beginning of this post, TX5pro-8189ftv_m9cMax_nokodi_ddr636-20..., basically i tried all the img matching S905X 2/16 Gb without any result
let me say that this red light comes apparently without any motivation, simply after working fine for a couple of years, one day pressing the same key on the remote nothing happened but the red light stuck
so looking for a solution I decided to use usb burning tool (that connects but stops at 7% - may be the driver on win is not correct?)
I'm experienced on bringing back to live other android devices, cells, tablets using TWRP, but in this case my tvbox desn't seem to respond to the reset button and no way to go into recovery by starting with the SD on
I'm banging against a wall, I need a deeper way or I must believe there is a hardware failure
There are currently 2454 users online. 0 members and 2454 guests.
