H96 PRO PLUS 3GB 32GB
Hello. Guys i am having trouble with my h96 pro plus i decided to upgrade to 7.1 for some reason i noticed screen would go black after a few seconds upgrading this would happened everytime i tried going back to 6.0 was successfull had to hold down the reset with pin through all the process now for some reason i have red ligh on the box i cant turn it on witj remote i have to u plug from the back and it starts fine also to turn off all good but tu turn it back on is the problem i have to keep unplgin and plug back so it can stary up.. any helps
ThanksTags: None
There are currently 2600 users online. 1 members and 2599 guests.
