MECOOL M8S PRO TV Box Amlogic 912 Android 7.1 3/32GB Dual WiFi Fast Lan BT4.1
    Brand: MECOOL
    Model: M8S PRO
    Type: TV Box
    Processor: Amlogic S912
    CPU: ARM Cortex-A53
    Core: 2.0GHz,Octa Core
    GPU: ARM Mali-T820MP3
    RAM: 3G RAM
    RAM Type: DDR4
    ROM: 32G ROM
    Maximum External Hard Drives Capacity: 32GB
    Decoder Format: H.265
    Video format: AVI,RM,RMVB,TS,VOB
    Audio format: AAC,APE,DDP,FLAC,HD,MP3,OGG,TrueHD,WAV,WMA
    Photo Format: BMP,GIF,JPEG,PNG,TIFF
    Support 5.1 Surround Sound Output: Yes
    5G WiFi: Yes
    Bluetooth: Bluetooth 4.1
    Power Supply: Charge Adapter
    Interface: AV,DC 5V,HDMI,LAN,TF card,USB2.0
    Language: Multi-language
    HDMI Version: 2.0
    Other Functions: 3D Games,3D Video,Airplay,DLNA,Miracast,NTSC,PAL
    HDMI Function: CEC
    System Bit: 64Bit
    WiFi Chip: QCA9377
    Power Type: External Power Adapter Mode
    Remote Controller Battery: 2 x AAA batteries ( not included )
    Product weight: 0.1100 kg
    Package weight: 0.4200 kg
    Product size (L x W x H): 10.20 x 10.20 x 2.10 cm / 4.02 x 4.02 x 0.83 inches
    Package size (L x W x H): 17.90 x 11.00 x 6.50 cm / 7.05 x 4.33 x 2.56 inches
    Package Contents: 1 x MECOOL M8S PRO Android 7.1 TV Box, 1 x Remote Control, 1 x HDMI Cable, 1 x Power Adapter, 1 x English Manual
    GEARBEST
      Much the same as its 3/16 baby brother.....except for some markings on Box and Packaging say 32GB instead of 16GB
      Different WiFi marked Chipped,
      Different Ram that Benchtests a little faster than the 16Gb unit better performance overall we can hope.
        CPU-Z
        UI for the MECOOL M8S PRO TV Box Amlogic 912 Android 7.1 3/32GB Dual WiFi Fast Lan BT4.1 same as other Mecool units so wont do it all again.
        Nice box, zippy enough and worth the extra for that little more
          I got this device a couple of days back (ordered from Banggood). The device gets stuck on MECOOL boot up image every 2 out of 3 times I reboot it. This happens even when the device isn't excessively hot right after I turn it on for the first time and I believe has something to do with the firmware. The version of the firmware the device came in was dated 05-05-2017 and the issue started before I installed any additional applications. When the device boots up fine it works with no issues. Any idea if it's a hardware issue and I have to go through the hassle of returning the unit back? The other issue I noticed which is likely hardware is that as soon as I plugin the HDMI cable when the device is powered on my subwoofer starts emitting constant low hum sound. When I unplug the cable the hum disappears. Not sure if anyone noticed similar issue with their units.
            How come your thermal is only 43 degrees? Mine is 60 degrees after the start up. How can I make it like that?
Name:
                Hallo,
                what is the difernece to the M8S PRO L? The PRO L is at AMAZON GERMANY much more expensive than the M8S Pro?
                  Originally posted by gueschmid View Post
                  Hallo,
                  Have you found the answer to this?
                    That is not CPU Temp. Use a CPU Temp app to get correct value.
                      Pro is always more than L on BangGood ! (or L is cheaper !!)
                      £62 vs £52 as of now.
                      Pro has better, DDR4 Ram.
                      Released without level1 Widevine, but now appears to have it (ask supplier : Caution Old Stock!)
                        I keep seeing that the DDR4 speed gain is barely noticeable.
                        Also, http://freaktab.com/forum/tv-player-...-tv-7-1/page21
                        it seems its still L3.
