Need a S912 based box that runs PlayStation VUE
    Looking for a box that will run the PlayStation VUE app. So far every box I've tried with a hacked mobile android OS is reported by the app as being rooted and it prevents the app from running.
    Why don't you just unroot the device?
      I can't connect my PS to the wifi or a ethernet cable. I need some help
        I've got almost the same issue when I was trying to connect my PS4 to the internet for the first time. Honestly, I thought that happened to me because of the internet connection issue, but that was caused because I could not create a PSN account and I could not connect to the PS store. I was trying to fix that by myself, but I could not manage it. So, I've started to search for the information on the internet, but a friend of mine helped me with that and he showed me this article https://www.router-reset.com I found all the necessary information about how to create a PSN account and I was able to do that following a couple of steps. So try this too, maybe this is the issue
