Help on buying an android TV box
    Dear folks, I would like to purchase an Android TV box but a dvb-c tuner is a must! Android 6.0 minimum..good apps compability, root and custom rom support would be awesome
    for now I know these manufacturers:
    Xoro hst 260 either dvb-c or s2 EUR 130,00
    K2 PRO Hybrid DVB-C/T/T2 Tuner EUR 160,00 (http://socomp.de/produkt/socomp-medi...mit-sat-tuner/)
    Wetek play 2 EUR 140,00
    MInix neo dvb-c (https://www.alibaba.com/product-deta...0.0.p2pmrb&s=p) EUR 120,00
    T95 (https://www.alibaba.com/product-deta...504804934.html) 35EUR
    X96 V88
    Sunvell T85k
    Which one would you advise to buy?
    I appreciate ur advises!
    Kind regards
    well.. wetek ( you can find for 129 euro from a DE dealer )
    note.. if you buy on alibaba...there is a chance for import tax
    Wetek has a forum...decent support
    good luck...
      So you would go with wetek?
      Bad thing is android 5.x os
