"Release" version firmware will be updated per month, you can download it click here
"Beta" version firmware will be updated per week, which is only for some enthusiasts who like to test some new problems and solved problems in advanced.
Egreat A5 EN Firmware V1.2.0.2 Beta
I. info
Egreat A5BD_EN_Firmware_20170517_v1.2.0.2_beta
Revised time: May 17, 2017, 17:24:58
MD5: FEA42650CE1CCB28A11D964E6370BF3B
DownloadLink:
http://data.egreatworld.com/A5BD_EN/...2.0.2_beta.rar
II.Firmware upgrade instruction
This version firmware has three ways to update, user data won’t be wiped.
1. OTA Update
This firmware is beta version, if you already updated to Beta V1.2.0.0, you can choose “Acceptable beta firmware” directly in “Setting-About”.Then the device will upgrade to newest beta firmware after you connect internet.
2. USB Update, please click here.
3. Forced refresh/recovery system, please click here.
III.Changelog
1.2.0.2 + 2.1.2 Beta
Posterwall: Fully support the UHD full rip
Posterwall: Added Blu-ray disc categories
Posterwall: Added direct delete file funcion in the poster wall
Posterwall: There is no need to search repeatedly when adding network locations
Posterwall: Fixed poster wall priority or file
Posterwall: Fixed the problem with lost paths
Posterwall: Fixed the problem with two duplicate paths
Posterwall: Increase search interface keyboard
Player: Fully support UHD full menu, main movie playback
System: Added the first screen is still for 30 seconds to automatically reduce brightness
System: Optimized screen saver(now completely shut down video output)
System: Fixed Transmission web interface without text problems
System: Update transimmison to version 2.92
System: LED display indicates the new marquee screen saver
Egreat
